What Does a Negative or Imaginary Partition Function Indicate?
4 replies · 3K views · last reply
santale
I have a partition function in euclidean quantum field theory. I have a parameter, let's say a charge, that I can change in the action that define the partition function.
I found that for small charge the partition function is positive, but there is a critical charge, above the one the partition function becomes negative.
Which is the meaning? Could this be interpreted as a phase transition?
General question: the partition function must be positive? which is the meaning of having an imaginary or negative partition function?
Thanks
How can you get a minus sign, the partition function always has the action part exponentiated. Or are you asking something else?
1) My action has an imaginary current as interaction (due to Wick rotation in from the theory in Minkowski space).
2) From the symmetry if the action I know that the functional integral is positive so the partition function is well defined (it's like the integral of Exp(-x^2+ i x)
3) I want to extimate the partition function through the saddle point method. I find a critical point (that in my case is imaginary) and I expand the theory around it, calculating the second order variation.
4) For small charge, the second order variations are positive, but when I pass a critical charge I find two negative eigenvalues of the second order variation, that gives a factor minus 1 (the negativity of the partition function I refered).
The question is: what does imply the fact that in this case the fact I have a negative contribution? Phase transition? The critical point around the one I was expanding the theory is no more good for large charge?
Thanks
You can evaluate the integral in closed form here, it will not be negative. Saddle point method is approximate, also which charge are you talking about? Are you using a scalar field theory with Wick rotation and coupling as charge, then it does not have a critical point.
The action is Euclidean Yang Mills couled with an heavy static source (this is the imaginary current):
$$F_{\mu\nu}F^{\mu\nu}+i\delta_{\mu0}A_{\mu}$$
Solving the euclidean yang mills equation, I have an imaginary solution.
