What does the 2.3 constant in e^Q/2.3RT come from?
  • Level: Undergrad
  • Thread starter Thread starter FQVBSina_Jesse
    Constant
FQVBSina_Jesse
TL;DR
Many activation energy/temperature dependance equations have the term e^Q/RT and often it is written as Q/(2.3RT). Where did this mysterious 2.3 come from?
Ok, I have actually found the answer from http://www.bristol.ac.uk/phys-pharm...ch/ugindex/m1_index/med_memb/file/Nernst1.htm.
Basically, a convenient way to analyze these equations is to take the log of both sides. Since e takes the natural log and the equations are usually in log base 10, the conversion factor between natural log and log10 is 2.303, simplified to 2.3. Since I didn't find an explicit question on this and someone else may have the same question, I will leave this post here if you don't mind.
Many energy/temperature relationships are given as an exponential term, such as the diffusion equation:
$$D(T) = D_0*e^{\frac {-Q_{ID}} {RT}}$$
Where D0 is the initial diffusivity material constant, QID is the activation energy, R is the gas constant, and T is temperature. And often right after this, the book would write it as:
$$D(T) = D_0*e^{\frac {-Q} {2.3RT}}$$
Where did this 2.3 come from?
Example: This book on page 228: https://books.google.com/books?id=gCcSBQAAQBAJ&lpg=PA228&ots=tvZtxC9VW5&dq=diffusivity Q/(2.3RT) where did 2.3 come from&pg=PA228#v=onepage&q=diffusivity Q/(2.3RT) where did 2.3 come from&f=false
It would appear, when it has the ## 2.3 \approx \ln{10} ##, the equation is written as ## D(T)=D_o \cdot 10^{\frac{-Q}{2.3 RT}} ##. Your "links" might contain this info, but it is difficult to scroll through the pages of your "links".
