What does the Center of Mass equation mean?
The Center of Mass (COM) equation represents a weighted average of the positions of point masses, specifically defined as r_{avg} = (m_1 * r_1 + m_2 * r_2) / (m_1 + m_2). This formulation illustrates that as mass 1 increases, the COM shifts closer to its position, regardless of mass 2's location. The total momentum of a system can be modeled as a particle with mass equal to the sum of the individual masses, demonstrating the relationship between COM and momentum. Understanding this concept is crucial for analyzing physical systems in one dimension.
  • Understanding of basic physics concepts, particularly momentum and mass.
  • Familiarity with weighted averages and their mathematical representation.
  • Knowledge of vector notation and operations in physics.
  • Basic algebra skills for manipulating equations.
  • Study the derivation of the Center of Mass equation in multi-dimensional systems.
  • Learn about the implications of the Center of Mass in collision physics.
  • Explore the relationship between Center of Mass and angular momentum.
  • Investigate applications of Center of Mass in engineering and robotics.
Students of physics, educators teaching mechanics, and professionals in engineering fields who require a solid understanding of the Center of Mass and its applications in real-world scenarios.
CollinsArg
4cae5e05ad478f54342da46937ea8fd5a3c2f256
How can I understand logically this equations? it seems to me like an avarage of equation...but why each term is specifically in the way it is? Thank you
It's a weighted average of the positions of the point masses 1 and 2. This means for instance that if the mass 1 is made large enough, the COM is close to the position of 1 no matter where 2 is.
Here's a way to see this weighted average.
For simplicity, work in 1 dimension.
Suppose I had five identical blocks, each with mass 1 kg,
that I place at various positions on a number line. Where is the [straight-]average position of those five blocks?
r_{avg}=\displaystyle\frac{r_1+r_2+r_3+r_4+r_5}{1+1+1+1+1}
Suppose there were two clumps... so that r_1=r_4 (so there are 2 at r_1) and r_2=r_3=r_5 (so there are 3 at r_2).
Then
<br /> \begin{eqnarray*}<br /> r_{avg}<br /> &amp;=&amp;\frac{(r_1+r_4)+ (r_2+r_3+r_5)}{(1+1)+(1+1+1)}\\<br /> &amp;=&amp;\frac{(2)r_1+ (3)r_2}{(2)+(3)}\\<br /> \end{eqnarray*}<br />
Instead of grouping by count, we could group by mass. (In this case of identical blocks, it doesn't matter numerically... but this suggests that you can take any quantitative property and conceptually break it down into units of that property). Think of multiplying the above by 1=\frac{{\rm\ kg}}{{\rm\ kg}}.
<br /> \begin{eqnarray*}<br /> r_{avg}<br /> &amp;=&amp;\frac{(2{\rm\ kg})r_1+ (3{\rm\ kg})r_2}{(2{\rm\ kg})+(3{\rm\ kg})}\\<br /> \end{eqnarray*}<br />
The physical reason why the center-of-mass is defined this way is because
the total momentum of a system of particles \vec P=m_1\vec v_1+m_2\vec v_2
can be modeled as a particle of mass M=m_1+m_2
with velocity \vec V=\frac{\vec P}{M}=\frac{m_1\vec v_1+m_2\vec v_2}{m_1+m_2}=\frac{d}{dt}\left( \frac{m_1\vec r_1+m_2\vec r_2}{m_1+m_2} \right)=\frac{d}{dt}\vec R
equal to the velocity of the center-of-mass.
(Off topic, but related.
By the way, the "average-velocity" is a time-weighted average of velocity:
\vec v_{avg}=\frac{\vec v_1 \Delta t_1 +\vec v_2 \Delta t_2}{\Delta t_1+\Delta t_2}=\frac{\Delta \vec x_1+\Delta \vec x_2}{\Delta t_1+\Delta t_2}=\frac{\Delta \vec x_{total}}{\Delta t_{total}}.
It annoys me that the textbook definition skips this interpretation by defining \vec v_{avg}\equiv \frac{\Delta \vec x_{total}}{\Delta t_{total}}.
Then it proceeds to define the [instantaneous] velocity as a limiting case of the average-velocity.
Maybe they skip the interpretation because it's strange to define a quantity in terms of its average.)
  • · Replies 19 ·
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 24 ·
