What does the Higgs particle consist of?
The discussion revolves around the composition and nature of the Higgs particle, exploring whether it is an elementary particle or if it could be composed of smaller constituents. Participants delve into the implications of the Higgs particle's decay and its classification within the Standard Model, addressing both theoretical and conceptual aspects.
  • Some participants assert that the Higgs particle is an elementary particle, not composed of anything else, similar to electrons and quarks.
  • Others propose that there are theories suggesting the Higgs could be a composite particle, referencing concepts like Technicolor descendants, though these theories lack verification.
  • A participant describes the Higgs process using an analogy involving a film star, suggesting that the Higgs gains mass through interactions, but this analogy is challenged as being a later invention rather than part of the original idea.
  • Concerns are raised about the implications of the Higgs particle's decay, with some questioning whether decay indicates that it is made of smaller components.
  • Participants discuss the nature of particle decay, arguing that decay does not imply composition, and that particles can transform into other particles without being made of smaller parts.
  • There is a discussion about the differences between annihilation events and the decay of the Higgs particle, with some participants noting that the outcomes of these processes can vary significantly.
  • Questions are posed about the possibility of producing a Higgs particle through high-energy collisions of other particles.
Participants generally agree that the Higgs particle is considered an elementary particle, but multiple competing views exist regarding its composition and the implications of its decay. The discussion remains unresolved on several points, particularly concerning the nature of particle decay and its implications for the Higgs particle.
Some claims about the Higgs particle's properties and decay processes depend on specific interpretations of particle physics, and there are unresolved questions regarding the implications of decay for the particle's classification.
  • #31
DanMP said:
I have more (and solid) reasons to ask and think about this new, lower level in the structure of matter and about the Higgs boson composition/formation in particular, but I'm not allowed to explain (personal ideas/theories are banned). All I can (and want to) say is that my reasons and my main theory are related with something we (you) don't yet understand, dark matter/energy, so it may add something of value to our current description of the Universe.
...okay.
  • #32
DanMP said:
I'm not very happy with the idea that "they are made of energy". This is too abstract.
Not more abstract than the electron itself, except for if you have ever seen an electron... ["made of" is not a nice expression]
The way we see particles is via their energy depositions in our detectors.
Now are particles mere energy? That's philosophy, but in some sense that's true, as you can produce them by colliding particles at necessary energies.
Imagination is good as long as it goes along with what we observe (look at mfb's post). If it's not, then it's irrelevant. Even if you want to add substructure to elementary particles, via means that they can still agree with the precision measurements, you will still need to introduce these new elementary particles and so on... [as the atom was replaced by protons,neutrons and electrons].
  • #33
DanMP said:
Imagine a concrete ball. That ball is not sand, nor gravel, nor water, it is something made from those ingredients (and more), but different ... and also a whole, not a system with moving parts (at least apparently). If you smash it, you obtain different pieces, with different shapes and proprieties (cutting edges, not rolling, etc.). Two or more smashed/crushed balls can be used to form a new concrete thing, maybe a cube. This is an analogy of what I meant with the "same stuff" as common ingredient for all "fundamental" particles.
A concrete ball is made out of atoms. If the elementary particles would be made out of something else in a similar way, all our predictions wouldn't have any reason to fit. But they fit - with excellent precision in cases like the electron g-factor.
DanMP said:
This means that the Higgs particle is an excitation in the Higgs field?
Exactly.
DanMP said:
How you digest this? I can't.
Whose fault is this? Did you learn QFT?
Calculate the electron g-factor. If the result agrees, publish it, then we can talk about it.
  • #34
ChrisVer said:
Not more abstract than the electron itself, ...
You are right.
Thank you for pointing out that, for a long period of time, the atom was considered elementary ...
  • #35
I think that this is the crux of the argument, and the core source of the confusion. The definition of being an “elemental particle” appears to become somewhat ambiguous.
As has been pointed out several times, there really is no “stuff” to a particle. It’s a “point” in space/time with zero spatial dimension but definable energetic qualities and quantities. Yet, with sufficient energetic input, the single point can become multiple points, suggesting intuitively that extra points were “hiding inside” the previously single point. Adding to the confusion is that there are various “forms” of energy that contribute to the particle manifestation.
Perhaps it would be helpful (and instructive to us laypeople) if one of you physicists attempted to define the concept of an “elemental” particle in terms of its energetic characteristics.
  • #36
That's your flaw. You make a suggestion that is based upon a misconception. You seem like you are trying to conserve something, when there is no such conservation law. The creation of particles/antiparticles is following other conservation laws (charge, energy/momentum, etc).
Again there is no intuition applicable/available if you haven't studied the theory that addresses the problem. Do that without a common ground of understanding the quantum world and you'll be discussing philosophy, as most of the popsci authors/spokespersons are doing.
  • #37
mfb said:
A concrete ball is made out of atoms. If the elementary particles would be made out of something else in a similar way, all our predictions wouldn't have any reason to fit. But they fit - with excellent precision in cases like the electron g-factor.Exactly.Whose fault is this? Did you learn QFT?Calculate the electron g-factor. If the result agrees, publish it, then we can talk about it.
I probably learned QFT long time ago, but I never used it, so I forgot most of it.
I searched QFT in Wikipedia and found this:
QFT was historically widely believed to be truly fundamental. It is now believed, primarily due to the continued failures of quantization of general relativity, to be only a very good low-energy approximation, i.e. an effective field theory, to some more fundamental theory.
You are right in most of what you wrote (electron g-factor, no mass in the gamma ray photons) and it is very hard to solve all the problems raised by this quest to a lower level, but not impossible. I have promising ideas ... The problem is that this is not my first goal ... Not even the second. Sorry.
Let's return to the Higgs particle, the main topic here. If the Higgs particle is an excitation in the Higgs field, how it decays in two or more excitations in other field(s)?
  • #38
Refresh your memory... on the same topic:
[itex]y_{ha} h \bar{\psi}_a \psi_a \in \mathcal{L}[/itex]
we "don't discuss personal ideas" here?
  • #39
How can you have "promising ideas" if you don't even remember the most basic basics of QFT? Seriously? If you want to improve physics you have to know exactly what has been done so far and what is left to improve. And to have that knowledge you have to study textbooks, not wikipedia...
  • #40
Sorry, but this is a B level topic. Please elaborate.
weirdoguy said:
How can you have "promising ideas"...
We don't discuss personal ideas here, so I can not answer.
Please focus on Higgs particle and, maybe, answer my last question.
  • #41
Although that was connected to "having studied QFT" (supposingly the standard model as well), the answer is simple:
It can: No violation of any known conservation law. Given that the coupling constants [itex]y_{ha}[/itex] are non-zero. the Higgs field is coupled with the 2 fermion fields (except for on-shell tops because that violates the conservation of energy).
  • #42
Before atoms could be actually studied, and often mainly in a philosophical way.
The situation is not comparable to today.
Let me be direct: No you do not, and you are wasting your time following "ideas" if you don't learn QFT first.
The Higgs field interacts with other fields - via the term ChrisVer posted.
  • #43
Apologies... I didn’t make my question clear. I was conceding that the “intuitive” concept was flawed. What I was hoping for was a layperson friendly explanation of the limiting energetic factors that define the “elemental” designation of a particle.
I suppose I should add that it would be more helpful if that definition wasn’t limited solely to the aspect of locality... such as, an elemental particle exists when all energetic parameters can be attributed to a specific point in space.
Is it possible to offer a succinct explanation of the limiting energetic factors at a specific point in space that, if exceeded or altered, result in new/different point particle manifestations. I suppose that this would simply be a list of the conserved energetic qualities/quantities at the given point in space, but there must be a reason for the energetic limits that dictate spontaneous decay into other particles.
  • #44
The particles have a set of quantum numbers that identify and define them. These can be the charge, the mass, the spin, and so on... those numbers originate from symmetries/conservations that manifest themselves in particle physics.
No. Possible decays (1 particle going to N others) are randomly taking place.
Interactions (2 or more particles going to N others) also have certain probabilities to give certain outcomes... eg colliding an electron with a positron with enough energy (to conserve it for the creation of masses for both outcomes) can give you a 2 photons, 2 muons, but it can also give you quarks.
  • #45
But, as we’ve seen with the Higgs boson, some particles are very unstable. They require extremely high energy collisions to be produced, and then decay “almost immediately”. That doesn’t seem completely random.
  • #46
Various particles have a larger or smaller chance of being created at a certain collision energy than others. But at any collision energy, the specific particles created are still determined randomly per their different "weights".
  • #47
First of all, it is random... a tau lepton let's say has a mean lifetime of about 0.3 picosecond... now when a particular tau lepton decays is randomly taken from some distribution (eg poisson)... the mean lifetime only tells you if you had a sample of 100 taus, after that time the taus that decayed were 100/e and so on...
Not very extreme... the protons had like 7-8TeV center-of-mass energy, but that's not the energy that goes into the collision of the proton constituents (that share only a small portion of that energy). The Higgs needs ~125GeV energy to be produced - you only have to make sure you collide things that are coupled to the Higgs more strongly than other particles, otherwise you'll be swelled in background. LHC, colliding protons, does not favor the production of Higgs BUT it bypassed that problem because it achieves a tremendous amount of collisions. The number of data is one important parameter; it made LHCb compete the B-factories that collide electrons-positrons. Oversimplifying, you can deduce a discovery with let's say 10 clean data collected over a year, or with 1,000,000 unclean data collected in 1 month (~12* for the year).
That's why probabilities are important. Something that is more or less probable is still random.
  • #48
Ok, thank you!
  • #49
All points conceded. You are both quite correct, of course. It’s all about energy requirements and probabilities, and the “elemental” aspect to particle manifestation really is limited to the locality of defining physical characteristics at an individual “point” in space/time.
As has always been the case, the frustration for curious laypeople like myself is that physical descriptions at the fundamental level always seem to be far more “informational” in nature than ontological. Yet, sadly, I realize that that’s unavoidable. How does one describe “energy” ontologically? It’s a philosophical issue, and not a scientific question. Apologies.
  • #50
It's unavoidable because there is no intuition for what happens at the quantum level. Even explaining the true nature of an atom is impossible and most people imagine atoms as the solar system: nucleus in the center and electrons revolving around it. Although that's a good approximation in some cases, it's not true or what quantum-mechanics tells us. How to go even more fundamental?
People who work with those get their intuition out of the formulas or actual observables. Eg the electron mass is clearly seen at the Na22 beta decay spectrum (the large spike at ~500keV),:
of course there are more such examples or different experiments but I remember this particular out of heart because I did the experiment during my undergrad and it was nice to see actual positrons-electrons there. An alternative one was the Thompson experiment to measure q/m of the electron, and it was also nice as you could see the trajectory of the electron beam (of course you saw the result of electrons passing through the gas-ionizing it and after the gas atoms fell at the ground state they'd radiate visible light -like fluoride lights).
