What does the term Action means in physics?
The term "Action" in physics refers to a quantity that describes the behavior of a physical system, typically defined as the integral of the Lagrangian between two points, denoted as S. In classical and quantum mechanics, the Principle of Least Action states that variations in the action should be zero, leading to the Euler-Lagrange equations. These equations reproduce Newton's laws when the Lagrangian is expressed as the difference between kinetic and potential energy. The discussion also highlights the relationship between action and forces, particularly in the context of Hamiltonian mechanics.
  • Understanding of Lagrangian Mechanics
  • Familiarity with the Principle of Least Action
  • Knowledge of Euler-Lagrange Equations
  • Basic concepts of variational calculus
  • Study the derivation of the Euler-Lagrange equations from the action principle
  • Explore the application of variational calculus in physics
  • Learn about Hamiltonian Mechanics and its relation to forces
  • Investigate the implications of the action principle in General Relativity
Students and professionals in physics, particularly those studying mechanics, theoretical physics, and anyone interested in the mathematical foundations of physical laws.
Himanshu
What does the term "Action" means in physics?
I don't know, but someone usually says it after "lights, camera..." :rolleyes:
The specific meaning of an 'action' in physics depends on what field one is working in. However, roughly speaking an 'action' is some quantity in a particular [physical] system that can be used to describe how that system behaves.
In mechanics (classical and quantum) the usual meaning is the integral of the Lagrangian between two points. It is usually denoted S. There are a few other versions as well, but they all involve the integral of a "path" (in generalized coordinates) between two points.
What is meant by varying an action ?
I've heard about somthing like " varying einstein-Hilbert Action to get the field equations".
What does that mean?
It means you take a variational derivative of the action. (A variational derivative is essentially the derivative of a functional with respect to a function. A functional is like a function, except that the input is a function and the output is another function). So, if you have an action that is a function of particle trajectory q(t), you can vary the action with respect to q(t): \delta \mathcal{S}[q(t)]/\delta q is the standard notation for a variational derivative.
The "Principle of Least Action" states that variations in the action should be zero (the name is really a misnomer, as it implies the action is a minimum when this condition is satisfied, but the action could be a maximum or a saddle).
In Lagrangian Mechanics, the action is defined
\mathcal{S} = \int_{t_1}^{t_2}dt L(q,\dot{q},t)
where q(t) is the trajectory of the system. Varying the action with respect to the particle trajectory q(t), after some integration by parts you arrive at
\delta \mathcal{S} = \delta\left(\int_{t_1}^{t_2}dt L(q,\dot{q},t)\right) = \int_{t_1}^{t_2}dt\left(\frac{d}{dt}\left(\frac{\partial L}{\partial \dot{q}} \right) - \frac{\partial L}{\partial q} \right) \delta q
where L is called the Lagrangian, and is assumed to be a function of t (either explicity or implicitly through the q(t)), q(t) and \dot{q} = dq/dt. We want this to be zero, and since \delta q is an arbitrary variation of q, it follows that what's in the brackets must be zero. This relation in the brackets is called the Euler-Lagrange Equations. (Plural because q(t) can really be a vector, and you have an Euler-Lagrange equation for each q_i).
It turns out that the Euler-Lagrange (EL) equations reproduce Newton's Equations when L = T - V, the kinetic energy minus the potential energy (it gets somewhat more complicated for things like General Relativity, which is the example you gave). So, if you can write down the Lagrangian for your system, then given the action defined as above, by varying it you would arrive at the EL equations, and plugging your Lagrangian into that you would derive the equations of motion for your system.
(As a last note, the EL equations above assume the Lagrangian does not depend on any time derivatives of q higher than \dot{q}. They become modified if it does).
i was surprized to see the word "force" so carefully omitted in the explanations. not to equate the two, but they're related.
Actually, when I studied Hamilitonian Mechanics, it was presented as a way of avoiding explicit enumeration of forces, which gets pretty complicated for complex systems. The point is that by expressing the fundamental principles in terms of the action, you don't have to mentions forces at all if you don't want to.
actually that's not entirely true for systems with constraints, the lagrange multipliers actually become the forces of constraint, and partial L withrespect to q are the forces related to the potential energy.
Yes, that's why I said "if you don't want to" - I was sweeping constraint forces under the rug, since I don't think mentioning them really clarifies the topic of this thread, i.e. the use of the action in Physics.
