What exactly is current, and how come it is constant in a circuit?
The discussion clarifies that electric current in a circuit remains constant throughout due to the principles of charge flow and coulomb interactions. The equation I = V/R illustrates that while resistance affects current, it does not create variations in current across different points in a circuit. The analogy of a traffic jam effectively demonstrates that if current were to vary, it would lead to an accumulation of charge, which is not feasible. Thus, in typical circuit sizes, the current is uniform, akin to water flowing steadily through a pipe.
  • Understanding of Ohm's Law (I = V/R)
  • Basic knowledge of electric charge and current
  • Familiarity with circuit components such as resistors
  • Concept of coulomb interactions in electrical circuits
  • Study the principles of electric charge conservation in circuits
  • Explore the concept of electric potential difference and its impact on current
  • Learn about the behavior of current in series and parallel circuits
  • Investigate the effects of variable resistance on circuit performance
Students studying electrical engineering, physics enthusiasts, and anyone seeking to understand the fundamentals of electric current in circuits.
rhfish
This is not exactly a homework problem, but it relates to homework problems. I have trouble understanding why exactly current in a circuit is the same everywhere.
Current is the rate of flow of charge, or "charge per second". Why wouldn't charge flow faster in some areas and slower than other areas? Why wouldn't passing through a resistor slow down the charge? Why wouldn't the charge speed up when the resistance decreased?
I = V/R
In the equation, if the resistance is lower, current should be higher. If there is variable resistance in a circuit (different types of wires say, or resistors), why wouldn't current be different in different places?
The whole circuit "feels" the effect of that resistor. It's kind of like a traffic jam. You can't have electrons all flowing at different rates and not expect collisions. These "collisions (more like coulomb interactions)" make sure that the current within a circuit is the same everywhere within that circuit.
If you had a circuit the size of light years, this may change...but usual circuits are small, and the effects are nearly instantaneous.
I can sort of see it, but not quite. In a traffic jam analogy, shouldn't the cars be able to theoretically all speed up together and increase the rate of flow? Or all slow down together and decrease the rate of flow?
ty
Here's a way of thinking about it. Suppose that at point A of a circuit, the current is I. Suppose that at point B, which is downstream from A, the current is I+0.1. That means that the wire between A and B would gain 0.1C of electrons every second. This can't happen, or else the wire segment would eventually have infinite charge.
To continue the traffic jam analogy, suppose cars can't leave the road or pass in between other cars. If 3 of the cars try to go faster than the other cars, they'd collide with the cars in front of them. If they try to go slower, they'd collide with the cars behind them. The cars can all change speed together, just as the current in a circuit can change depending on its resistance.
Electrons can slow down in parts of a circuit, but wherever that happens they will be bunched closer together. The number of electrons passing by a point will be the same everywhere in the circuit loop, and that is the current.
I would compare electric current in a circuit to the water flowing in a pipe.
