What Generator for Hydropower Demonstration Setup?
The discussion revolves around selecting an appropriate generator for a prototype hydropower plant intended for educational purposes. Participants explore various generator types, configurations, and operational parameters related to the setup, including the use of a Pelton wheel, water flow rates, and the desired output frequency.
  • One participant describes a hydropower setup involving a water tank, pump, Pelton wheel, and generator, seeking advice on generator selection.
  • Another participant suggests using pulleys and belts to decouple the turbine and generator speeds, noting that Pelton wheels require higher pressures.
  • There is a discussion about the generator type, with suggestions for using an automobile alternator or a three-phase motor as a generator, with considerations for safety and output type.
  • Some participants express uncertainty about the relationship between turbine rotation speed and generator output frequency, with one noting that the generator's speed can be adjusted based on its connection to the turbine.
  • Concerns are raised about the need for a generator that can maintain output over varying speeds, with recommendations for simpler designs to enhance project feasibility.
  • One participant emphasizes the importance of safety and the KISS (Keep It Simple, Stupid) principle in the design process.
Participants express a range of opinions on the best generator type and configuration, with no clear consensus reached. There are differing views on whether to use an automobile alternator or a converted motor, as well as on the specifics of maintaining the desired operational parameters.
Participants mention various operational parameters such as water flow rates, pressure requirements, and the need for AC output, but these details remain unresolved in terms of their implications for generator selection.
Individuals interested in small-scale hydropower projects, educational demonstrations of energy generation, and those exploring generator configurations for variable speed applications may find this discussion relevant.
HueHue
Ok, So I'm bulding a prototype of a hydropower plant, that will be used to teach kids.
I have NO CLUE about what generator to use.
So here's how it works (check the attached pic):
- We have a water tank
- A pump pulls the water from the tank
- the water is used in a pelton wheel
- a generator will use the turbine rotation to create eletricity
- there will eletric loads after the generator
Ok, so our teacher told us to keep the turbine rotation at 60Hz and H=2 bar. It's going to be a self controlled system.
The kids are going to play with the loads -> let's say they increase the load, so the turbine will slow down
the valve is going to open to take the turbine rotation back to 60Hz (motor controlled valve)
as the flow increases, H decreases
then the frequency inverter is going to increase the frequency of the 3 phase motor of the pump, so it goes back to the original pressure (H=2 bar)
(check this http://bit.ly/1YsqKpr )
With the turbine rotating at 60Hz, will the generator too?
Well, I don't even know what to ask... Help me out please
Thanks in advance
<< Mentor Note -- Two cross-posted threads merged >>
Neat project. On a previous thread there were some very helpful YouTube videos. I'll try to find them for you tomorrow.
It is likely that you will want some pulleys and belts so that the generator shaft speed does not need to match the turbine shaft speed.
How much vertical head (water height) do you have? I ask because Pelton wheels need higher pressures than other types of turbines. You say 2 bars, that is roughly 20 meters of head.
Your narrative about 60 hertz and inverter and three phase motor sounds jumbled. What kind of generator will you have AC? DC? How much power must you generate? How much water flow do you have?
Thanks a lot.
Yes, probably pulleys and belts so I can work with smaller rotations on the turbine, right? 1:4
Well, I'll be using a water pump to pull water from a water tank. I can work with the pressure. Btw, the pelton turbine I have is small (check attached pic).
Yes, what I said about keeping the pelton wheel in 60 Hz doesn't make sense, because it's rotation depends on how much rotation I need on the generator.
About the generator.. Well, I couldn't find a small generator/alternator so I'll probably use an inverted 3 phase motor as generator (not sure yet). I don't need much power, I think I'll be lighting a few light bulbs as a load.
I'll work it with water pump as well. I have no clue about the volume of the water tank yet.Just to clarify what I said before about the inverter and the 3 phase motor of the water pump...
Let's say we are working with a flow of 3.2l/s, pressure of 2 bar, and that this outputs 60Hz on the generator.
Then someone lights more light bulbs.
By doing so, the frequency on the generator is going to go down a bit, let's say it goes down to 50Hz.
Then I'll open the valve a bit to increase water flow (lets say it goes to 5l/s), making the turbine go faster, and thus making the generator output 60Hz again. Ok.
But by increasing the flow, the pressure is going to go down a bit. Let's say it goes down to 1 bar.
The pressure must be kept at 2 bar (proper simulation of a waterfall (constant height, constant pressure)).
To fix the pressure, I'll increase the frequency on the 3 phase motor of the pump, with the frequency inverter.
Q: water flow , N: frequency of the 3 phase motor of the pump , H: pressure
Q1= 3.2l/s , Q2= 5l/s , H1= 2 bar , H2= 1 bar
Let's say we had N1= 100Hz
By increasing N, we can change the point of operation of the pump.
So by increasing N we can increase the pressure (taking it back to 2 bar), without changing the flow.
Check the other picture :)Thanks a lot for your help!
How fast the generator turns depends on how it is connected to the turbine ... if you connect it via gears, then it could turn faster or slower.
If the connection is stiff, it could turn slower anyway.
Your options are wide open.
A stiffer generator will get you more power per rotation, but it may be to stiff for the water to turn.
It is common to use an electric motor as a generator in these sorts of demonstrations... I've seen a waterwheel build from an old bike turn an electric drill to generate power.
Here is the video I was thinking of. It uses a waterwheel instead of a pelton wheel. However the owner did an excellent engineering job of keeping is simple (KISS) and making it practical.
I think that you should consider an automobile alternator for the generator.
  • You can get one at low cost at a junk yard.
  • 12DC is much safer than 120VAC, especially when you plan to have kids experimenting with loads.
  • An alternator is designed to give nearly constant output over a wide range of speeds, so a speed controller may not be necessary (KISS again)
  • As shown in the video, use pulleys and a belt to make both the turbine and the alternator run at their optimum RPM.
Thanks a lot, you're so right about the connection.
Yes, I've read I can use a 3 phase motor inverted as generator... Thing is... The university is going to buy it for us, so why not pick a proper generator?
Thanks a lot again!
The thing is
The university is going to buy the stuff I need, so why not pick a proper generator? Instead of having to spend hours converting the motor
The output must be AC, because we are simulating a hydropower plant
Thanks a lot!
HueHue said:
Thanks a lot again!
The thing is
Thanks a lot!
OK, you have thousands of AC motors/generators to choose from.
Regardless of who pays the bill, please keep three things in mind.
  1. Safety.
  2. The KISS principle. (KISS increases the chances that any project actually gets finished.)
  3. Requirements. (Clearly stating all requirements before beginning design is a sound engineering principle.)
I would try to keep the voltage low and an automotive alternator would work for this. Simply remove the internal rectifier and regulator and take 3 phase AC from it. This is exactly how a power plant would be except you would have the safety of a lower voltage. After all, this is a simulation right? And not the real thing.
