jim mcnamara said:
@Ygggdrasil okay.
Consider:
What happens in alternation of generations when the "dominant" phase of the organism is not diploid, but haploid instead? Apoptosis?
What I'm really asking - is this the driving force behind polyploidy? Improved DNA repair?
When there is a haploid generation, there will be stronger selection against any recessives or haploid insufficient loci. The recessives would be "revealed (normally they are hidden as recessives behind the other alleles and are therefore cryptic)". Any haploid insufficient (often deletions of part of one of the chromosome (could be small), leaving only one gene to do all the work in a diploid organism, which sometimes works OK), would similarly be exposed to stronger selection. These cases of stronger selection could be severe enough to cause death (a lethal) or reduce or eliminate reproductive ability (a sterile). This should result to some extent in the reduction of these mutations of the population's genetic background.
These mutations should only affect their organism, if they are expressed or have some function during the time when they are haploid. The same thing would apply to our haploid sperm and egg cells, however, these cells could be loaded up with gene products from neighboring cells or from their lineal precursors (the cells they came from).
For many cases, it is probably not the driving force behind polyploidy.
One case, in Drosophila salivary glands (a specific tissue) there is extreme polyploidy (maybe 2,000 x). My understanding is that this tissue specific polyploidy is to support the larger metabolic activity of those cells, but not sure).
Several organisms (like sunflowers) are polyploid as a result of hybridizing. In cases like these, I would guess that the immediate driving has to do with the mechanics of cell division and chromosome segregation.
Polyploid producing events can produce a lot of extra gene copies.
The lineage leading to us humans has undergone two rounds of whole genome duplications, However, we are not octiploid (8x) because most of the duplicate genes are either modified to new and different functional products or are not maintained by selection a(to maintain the older function(s) of the gene), while the second copy can then be modified (either in the encoded gene product or in the non-transcript-encoding control sequences) to assume evolutionary new functions through a minimal amount of sequence changes.
Because fewer changes are required to generate a meaningful (meaning adaptive) new gene, this speeds up evolution.
