What Happens to sin(i) for Complex i?
  • Context: Undergrad
  • Thread starter Thread starter hadi amiri 4
57 replies · 9K views
hadi amiri 4
can anyone tell me that what is i([tex]\sqrt{-1}[/tex])
I can not understand the existence of this
pre unive math
hadi amiri 4 said:
pre unive math
Well, then you know about 2-D coordinates, don't you?
Instead of considering the quantities that lie on the real number line (i.e, the so-called "real" numbers!), let our basic "quantities" be points in the PLANE in stead.
We will call these quantities "complex numbers".
Now, each such "complex number" can be said to have two components, each of which is a standard real number, just like the coordinates for a point in the plane are given by, say, (x,y) where "x" is the "x-coordinate" and "y" the "y-coordinate"
Now, we want to DO SOMETHING with our new complex numbers, in particular, we want to be able to "multiply" two such numbers together. (Note that we here introduce a new meaning to the word "multiply" , namely as an operation between two points in the plane (i.e, our complex numbers!), rather than an operation between two numbers on the number line!)
Let two complex numbers have the shape (a,b) and (c,d) where a,b,c,d are ordinary real numbers.
Furthermore, let us introduce the short-hand symbol "i" for the point (0,1), that is i=(0,1), and in addition, we let the symbol ""1"" be defined as: "1"=(1,0), and, also, "-1"=(-1,0).
Now, we introduce a general multiplication rule:
(a,b)*(c,d)=(ac-bd,ad+bc)
Thus, let us multiply "i" with itself!
i*i=(0,1)*(0,1)=(0*0-1*1,0*1+1*0)=(-1,0)="-1"
That is, i*i equals the complex number we have called "-1"!
Furthermore, we will now look at those numbers that lie on just the x-axis, say numbers of the form (a,0) and (c,0).
What happens when we multiply two such numbers together?
Then we get:
(a,0)*(c,0)=(ac-0*0,a*0+0*a)=(ac,0)
THat is, we get a number ON the x-axis whose coordinate value equals exactly the product a*c, and we can therefore IDENTIFY the x-axis with our ordinary number line!
THe complex numbers constitute therefore a number PLANE, where we call the x-axis the "real axis", whereas the y-axis is called the "imaginary axis".
The number "i" lies therefore ON the "imaginary axis", has unit length, so we call it the "imaginary unit".
Thus, that i*i=-1 is something we are able to construct as long as we regard our NUMBERS as points in the plane, and in addition, have defined our "multiplication" in a smart manner as above.
Hi hadi amiri 4! :smile:
nicksauce is right … i is defined as a square-root of -1.
Mathematicians can define anything they like.
i does not exist.
Or, rather, it only exists in mathematicians' imaginations.
Why does its existence worry you? :smile:
You already know that i is the imaginary unit, so you then know that i([tex]/sqrt{-1}[/tex]) is the same as i*i, which is -1.
i does not exist.
i exists just as much as the number 1. i is simply the element (0, 1) of the field formed by R^2 over addition and multiplication of complex numbers. That i^2 = -1 is simply due to the definition of multiplication for complex numbers. Also, to be clear, 1 in C is not the same as 1 in R. They are different objects; one is an ordered pair while the other is atomic, let alone the fact that they come from different fields. For convenience, we abbreviate (x, 0) as x and (0, y) as y*i. The pair (0, 1) exists just as much as the pair (1, 0).
Nice! But I suspect a student's ability to appreciate this will depend strongly on whether or not they have been taught mathematics axiomatically.
Remember, math is a relatively arbitrary field. Something can be made valid so long as it serves a purpose that does not hold too many heavy contradictions. The number 1 is a concept and so is i. The number 0 is a concept and so is i (it can even be more mysterious than i).
Pre-university schools (and even universities can) have a crude way of teaching math...its very mechanical and rigid...it does not present any elegance and it pretends to put unnecessary boundaries between the several different categories. You could gain a better perspective from reading journals, etc... (how Gokul43201 said it).
i does not exist.
Oh, tiny-tim, what were you thinking? "i" only exists in mathematician's imaginations in exactly the same way other abstract things, like the numbers "e", or "1/2", or "1" do. I understand that but the person who wrote the original post is certain to misunderstand it.
Oh, and as I am sure you have seen from my previous posts, I object to the bald statement "i is defined as a square root of -1". You did put "a" which a good thing but a definition has to specify it exactly. That does not say which of the two square roots of -1 is i.
Redbelly98 said:
It occurred to me some time ago that this definition is ambiguous, since there are two solutions to that equation.
While this ambiguity does not seem to matter in practice, I'm still surprised that it never seems to get discussed.
I hadn't thought of that, both +i and -i are solutions, but how can you say that one is the positive root and the other is the negative root? Hmmm, very interesting comment. I guess that is the ultimate source of conjugate symmetry.
Agreed!
It would be interesting to see what the orinal poster makes out of it.
It is discussed. In one loose sense it is the starting point of Galois theory. In fact some mathematicians make a point of only using the symbol [itex]\sqrt{-1}[/itex] to avoid having to make a choice of square root of -1.
The most basic definition of i
Hi Werg22!
hmm … this is obviously a usage of the word "simply" that I haven't come across before … :wink:
Hi HallsofIvy! :smile:
Sorry, but I think numbers like 1 2 3 … existed even in cavemen's imaginations.
And when it came to dividing food, so did numbers like 1/2.
e = 2.71828182889045etc is of course a much more recent invention of mathematicians … but is it an invention?
If you defined it (using that decimal series) it to a layman, surely the layman would reply "You haven't defined anything new … you've only given a name to something which I see no use for! I wish you well with it! But it was already there before you gave it that name … you didn't define it, you only named it!"
But i wasn't there before …
:smile: if so, where was it? :smile:
In that sense, hadi amiri 4 is quite right to question its existence! :smile:
erm … sorry … what posts? :confused:
"i" can be defined in many ways.
Here's one definition: add a symbol "i" to the field R, define ii = -1, and then enlarge to a field.
Obviously, there are no other elements of the new field whose square is -1, except for -i.
What's wrong with that?
All other definitions (the Argand plane construction, the pairs construction, etc) are just models of this definition.
And this definition … of i as a thing whose square is -1 … is the most basic. :smile:
So you don't think they exist in any real sense any more nor less than a symbol that squares to give -1?
Just because you can think of a 'real life' situation where things like 1,2,3 are useful, and describe some properties doesn't mean that these descriptors have a physical reality in this, or any (platonic) realm. My standard line is: the second I stub my toe on a '1', I'll believe it exists in a meaningful sense. The counter point is: when you stick your hand in the electric socket, it isn't the imaginary part of the current that kills you.
… it doesn't really hurt …
Hi matt! :smile:
But does your toe exist? or is it just a convenient name for an electromagnetic field with such a strong boundary that it repels what we choose to call the electromagnetic fields of other things? :smile:
My toe certainly does exist, and you just described what it is. You didn't do that for the number 1. In fact all you will do is produce examples of 'one of something', such as one sheep, or one toe.
Wait...to sidetrack just a little...what are the physical meanings i can hold (is it only applicable as a mathematical concept)?
we know that
[tex]\sqrt{a}[/tex][tex]\sqrt{b}[/tex]=[tex]\sqrt{ab}[/tex]
so
[tex]\sqrt{-1}[/tex][tex]\sqrt{-1}[/tex]=[tex]\sqrt{-1*-1}[/tex]=[tex]\sqrt{1}[/tex]
=1
and i^2=-1
finally 1=-1
we know that
so
=1
and i^2=-1
finally 1=-1
Do you see the errors you made in there? For one thing, [tex]\sqrt{a}[/tex][tex]\sqrt{b}[/tex]=[tex]\sqrt{ab}[/tex] works for real numbers, but not always complex/imaginary numbers. Also, [tex]\sqrt{1}[/tex] has two answers, -1 and 1, just as [tex]\sqrt{25}[/tex] has the two roots -5 and 5 and [tex]\sqrt{-9}[/tex] has (-3)i, 3i, 3(-i) and (-3)(-i). You could even go to say that [tex]\sqrt{-9}[/tex] has the root -3i[tex]^{5}[/tex].
But really, [tex]\sqrt{-1}[/tex][tex]\sqrt{-1}[/tex]=[tex]\sqrt{-1*-1}[/tex]=[tex]\sqrt{1}[/tex]=-1
hadi amiri 4 said:
we know that
so
=1
and i^2=-1
finally 1=-1
Only in your imaginary world
tiny-tim said:
Hi Werg22!
You assume that cavement couldn't be mathematiciains? Do you write Geico commercials?
I will confess that when I wrote that I really meant that all numbers exist in the imagination. I only said a mathematician's imagination because you did and I wanted to agree with you as much as possible. Did you really intend to say that only professional mathematicians can conceive of the number i?
1/2 of an apple is an object. 1/2 of a loaf of bread is an object. "1/2" is none of those things.
No, it is not. In fact, that is not a definition at all because, again, in the real number system there is no such thing while in the complex number system there are two and that definition doesn't tell us which of the two is i.
It is useful in electrical engineering and signal processing and anytime you are doing a Fourier transform. Perhaps there are other applications also, but that is the field that I use it in. In the Fourier transform and signal processing complex numbers are used to represent phase information and i is a phase shift of 90º wrt 1 (i.e. a sin rather than a cos).
i is a mathematical entity equatable to pi.
i exists in the sense that pi exists -- that is, under special situations, it is a value that arrises naturally. A cartesian coordinate system does not "exist," but it most certainly behaves as if it does when we use trignometry to measure apparent size, paralax, or a number of other things (and in these contexts, pi also appears.)
i is easily demonstrated to exist in the same sense as pi via observing the "addition" of forces. Pi let's us represent angle, for example Pi/4 rads over "level" yields maximum distance when firing a cannon, and complex values allow us to "add" forces (as well as other useful applications.) Anyone claiming that i does not "exist" must also concede that pi does not "exist." (In fact, after studying complex analysis, I would have to say that complex numbers are the "true" numbers, making coherence of ambigous concepts such as "limits at infinity," "rotation," and other topologies.)
I'm not an expert though, and I have no room to mention topology considering I have almost no experience in the field. Still, I feel that complex numbers are extremely real -- perhaps more so than even integers (well, that's going a bit far, but still.)
Careful now! Strictly speaking you have just said that [itex]e= \pi[/itex]!
Yes, and, I would argue (and have here), in the same sense that any number exists!
