What Happens When the V Matrix is Zero in SVD?
  • Context: Graduate
  • Thread starter Thread starter SELFMADE
    Matrix Svd Zero
5 replies · 3K views
SELFMADE
Semester is over but still want to figure this out
Prob 8 on here:
http://www.math.uic.edu/~akers/310PracticeFinal.pdf
When trying to SVD that matrix one of the U or V matrix turns out to be zero but the answer key has just the general formula for SVD
can anyone explain thanks
Prob 8 on here:
U and V can't be zero. The the definition of the SVD says they are orthonormal matrices.
How are you doing this by hand? One way is to finding the eigenvalues and vectors of A^T.A and A.A^T . The U and V matrices are the eigenvectors of those matrices, so it doesn't make any sense for them to be zero.
Since the eigenvalues of O*O are all 0, Σ would be the same exact zero matrix as the given. SVD is unique only to Σ in general, so you can pick any orthonormal bases for your domain and codomain and you have U and V.
Are you sure about that?
A = U S VT
AT A = V S UT U S VT = V S2 VT
AT A V = V S2 VT V = V S2
So S2 and V are the eigenvalues and vectors of AT A
Except in the special case where there are repeated eigenvalues, V is uniquely defined (apart from scaling factors of +/-1).
Starting with A AT, the same is true of U.
But in the case of T:R^2 -> R^2 where T is the zero transformation, any two linearly independent vectors from R^2 can be eigenvectors of T. Even with the restriction that the two eigenvectors we pick from R^2 are orthogonal, there's more than one way we can pick the vectors aside from ordering. Since his matrix in question is specifically the zero matrix, the pathological example is actually relevant.
I think the OP's problem was that he got a zero V matrix, but that is wrong. Since we don't know what he/she actually did to get V = 0, it's impossible to say what the mistake was.
If you look at the question in the OP's link, the matrix does not have any repeated singular values.
I agree that U and V are not unique if there are repeated singular values.
