What happens when we connect 2 batteries + with +, - with -?
10 replies · 2K views
CasterlyRock
Batteries are connected together with their + and - poles.
I quess that nothing happens because there is no change in potential difference.
Exactly. Assuming of course that the two batteries do have the same voltage, nothing will happen. (If you connect them + to - and - to +, the two batteries will quickly drain and the wires connecting them may over heat. Not a good thing to do!)
CasterlyRock said:
I quess that nothing happens because there is no voltage difference.
Sounds reasonable. Are you possibly also supposed to make an observation about the properties of the resulting battery pair?
No, it only says that batteries are the same.
I meant properties of the pair after connection compared to a single battery. Volts? Amps? Amp-hour capacity?
Really nothing except what I wrote. The question has a conceptual nature. I assumed that when connected, batteries are in parallel, that means the same potential as it was, so nothing changes.
Could you not say that you produced a "new" battery with the same volts, but twice the amp and amp-hour capacity?
I don't understand. Do you mean if I would apply a resistor to that new one battery (lets say a resistor is a lightbulb) it would shine brighter than one applied to the original battery?
Why would it shine brighter with the same volts applied?
P=I^2*R. You've said that amp is greater than before.
No, I said the amp capacity is greater than before. How much greater?
