What if c is variable rather than constant?
  • Level: Undergrad
  • Thread starter Thread starter Azhar
14 replies · 2K views · last reply
Azhar
TL;DR
If c is variable rather than constant then travel more than light velocity is not impossible
What if c is not constant,example:
c_2=c+1000 km/s
v_1=c_2
v_2=c
(v_1+v_2)÷(1+v_1×v_2÷c_2²)
The result is c_2 so to calculate particle that the velocity is more than light the limit should be more than light too,maybe particle that travel faster than light is not impossible but doesn't exist in tangible nature,what if 0 invariant mass mean the particle travel in the limit so if the limit is c then photon invariant mass is 0 but if the limit is c_2 photon invariant mass is non zero,what if the formula is accurate because the formula measure particle that travel in light speed or less than light speed,what if tachyon is result of more than light velocity but calculate with light velocity limit
Azhar said:
TL;DR: If c is not constant then light speed is not limit
What if c is not constant, ...
In physics today, light is defined to have a constant velocity.
c = 299,792,458 m/s.
The light velocity is constant but what if the c is not,like c is variable in formula that act as limit rather than constant
It depends what else you vary. Because the fine structure constant is ##\alpha=e^2(4\pi\varepsilon_0\hbar c)^{-1}## you can't vary ##c## without also varying at least one of ##e## (the electronic charge), ##\varepsilon_0##, ##\hbar## or ##\alpha##. It turns out that if you also vary ##\alpha## then the change has physical consequences. Otherwise, the other thing(s) you changed make balancing changes and it turns out that the whole process is nothing more than a unit redefinition.
We have looked for variation in the fine structure constant and have not seen any evidence.
Undergraduate answer:
There are two different "c"s. One is just a unit conversion between space and time, its numerical value depends on your choice of units, so "changing it" can be nothing more than a unit redefinition.
The other is the physical principle that there's a single invariant top speed for information/causality; that's the real content, and it's never been contradicted.
Your example doesn't beat the limit, putting c₂ into the formula just gives c₂ back, so you've only renamed the limit, not exceeded it.
But the result is c_2 and c_2>c so the c_2 result break c
Your ##c_2## doesn’t have any physical meaning. It is just a number, and doesn’t break anything in physics
It isn’t. There can only be one invariant speed.
"what if the formula is accurate because the formula measure particle that travel in light speed or less than light speed"
that's the text,you quote "what if the formula is accurate"
But sure agree to your reply
Are you asking if it's possible that light doesn't travel at ##c## in vacuum? If so, yes, it would happen if the photon had mass. The physics of a massive photon are understood, and we actually use this theory to measure the photon mass. So far it's indistinguishable from zero.
By "variable speed of light," do you mean that if you accelerate to *c* in a race against a pulse of light, the pulse accelerates to 2*c* so that it is always moving at *c* relative to you? Something like that?
Azhar said:
"what if ...
... you learned the special theory of relativity?
Then, you'd understand your question makes no sense.
##c## is not just constant, it's invariant. You need to learn what that means.
  • Agree
In empty space, from Maxwell: light speed =c, Respect to what? -> Einstein said respect to nothing -> SR
Einstein rather said: with respect to anything
  • Agree
Agreed. My wording was imprecise, I meant that there is no preferred (privileged) reference frame.
