What is a free vector and how does it relate to vectors in spacetime?
  • Context: Undergrad
  • Thread starter Thread starter Stella.Physics
    Vector
The discussion revolves around the concept of "free vectors" and their relationship to vectors in spacetime, particularly in the context of General Relativity (GR). Participants explore the definitions and implications of free vectors versus non-free vectors, examining their behavior in different coordinate systems and their dependence on specific events in spacetime.
  • Some participants suggest that "free vectors" are a familiar notion from Euclidean geometry, where vectors can be compared across different points.
  • Others argue that in the context of spacetime, vectors are fixed at specific events, and thus cannot be freely moved or compared without reference to their coordinates.
  • A participant explains that in Cartesian coordinates, a vector can be represented consistently across the plane, while in polar coordinates, its representation changes based on the location.
  • There is a discussion about the implications of moving vectors in different coordinate systems, with some asserting that a vector's meaning is tied to its specific coordinates.
  • One participant questions the concept of a vector being able to "move" and introduces the idea of a vector field, suggesting that it describes values over a range of locations.
Participants express differing views on the nature of free vectors and their applicability in spacetime. There is no consensus on the definitions and implications of free versus non-free vectors, and the discussion remains unresolved.
Participants highlight the limitations of using different coordinate systems, noting that the representation of vectors can vary significantly depending on the chosen coordinates. There is also an acknowledgment of the need to specify points in spacetime when discussing vectors.
Stella.Physics
Nugatory said:
If you want to get into GR as quickly as possible, https://preposterousuniverse.com/wp-content/uploads/2015/08/grtinypdf.pdf is a good practical summary. Just be warned that in this context "practical" means "ignores all mathematical niceties not required to get results out of the machinery".
Hello there, I had a look at the notes you shared and I have a question
what does "Vectors in spacetime are always fixed at an event; there is no such thing as a “free vector” that can move from place to place" mean?
so okay, an event is when you fix the coordinates of time and space , so of course this comes with a vector of 4-coordinates, but what would a free vector be?
Its not a technical term that has a physical\mathematical meaning, actually its supposed to be the familiar notion everyone has about vectors from the Euclidean case. In the Euclidean case, you can compare vectors in different points. For example you can compare angular momenta of two particles in two different positions. As if you can move one of them to the location of the other and see which is longer. The vectors are free in this way. I should emphasize that this is not technical term.
So you cannot "move" them around mathematically for comparison etc because they have meaning only when connected with an event? Like they don't have much info or meaning except when connected strictly with some very specified coordinates?
You're surely comfortable with vectors written in Cartesian coordinates. Let's take an example in ordinary two dimensional space, as on the surface of a sheet of paper. We'd write a vector ##V## of length 2 and pointing towards the top of the sheet (in the positive y direction) as ##\vec{V}=0\hat{x}+2\hat{y}##, or more concisely as ##(0,2)##. In the notation of the notes that started this thread, we'd say ##V^0=0## and ##V^1=2##. As long as we're using cartesian coordinates, that representation works anywhere; a vector of length two pointing straight up everywhere will be ##(0,2)## everywhere. This is a free vector.
But suppose that we were using polar coordinates... ##\vec{V}## still is a vector of length two and pointing straight up, but it will have different components at different places. At the point corresponding to cartesian coordinates ##(x=1,y=0)## we have ##\vec{V}=0\hat{r}+2\hat{\theta}=(0,2)##. At the point corresponding to cartesian coordinates ##(x=0,y=1)## we have ##\vec{V}=2\hat{r}+0\hat{\theta}=(2,0)##, and at the point corresponding to cartesian coordinates ##(x=-1,y=0)## we have ##\vec{V}=0\hat{r}-2\hat{\theta}=(0,-2)##. Now when we say ##(0,2)##, we also have to specify the point that we're talking about, because ##(0,2)## means different things at different places. That's a vector that isn't free.
Nugatory said:
As long as we're using Cartesian coordinates, that representation works anywhere; a vector of length two pointing straight up everywhere will be ##(0,2)## everywhere. This is a free vector.
thank you so much, that was very helpful! So a non free vector is one that could be at any place , since many functions lead to these points, so we need to specify which point of spacetime.
But, for the Cartesian case, it wouldn't work everywhere, but only in the point of x=0 so we could move the vector facing upwards, up and down the y-axis, but not on the x-axis, since x is zero.
Another point is that, if I get this right, 0 corresponds to time coordinate whereas 1,2,3 are for spatial coordinates, do I get this right? I guess you used 0 for x for simplicity.
It works everywhere. The vector is ##0\hat{x}+2\hat{y}## where ##\hat{x}## and ##\hat{y}## are unit vectors in the x and y directions. No matter where you are on the plane, that vector will point up, in the positive y direction.
right.
I wonder what you actually mean by a vector that can move about. A vector involves magnitude and direction and not an 'origin'. You can have a Vector Field which describes the values of a vector quantity over a range of locations. There is an idea of 'freedom' there(?).
  • · Replies 38 ·
  • · Replies 39 ·
  • · Replies 146 ·
11K
  • · Replies 95 ·
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 37 ·
  • · Replies 50 ·
