I_am_learning
- 681
- 16
I never actually understood what exactly is a Hole? Could you explain it clearly.
The discussion centers on the concept of a "hole" in semiconductor physics, defined as the absence of an electron. Participants clarify that holes behave like positive charges, influencing current flow and Hall voltage measurements. The Hall effect demonstrates that the movement of holes and electrons can lead to positive or negative Hall voltages depending on their respective velocities and the magnetic field direction. The conversation emphasizes the complexity of modeling holes, particularly in P-type materials, and the necessity of understanding their role in current flow and charge carrier dynamics.
PREREQUISITESElectrical engineers, physicists, and students studying semiconductor technology, particularly those interested in the behavior of charge carriers and the implications of the Hall effect in materials science.
thecritic said:I never actually understood what exactly is a Hole? Could you explain it clearly.
If B is along +ve z and either velocity of holes is in +ve x or velocity of electrons is in -ve x, Hall voltage is +ve.thecritic said:But that don't seem to explain the whole story. If movement of holes were actually movement of negatively charged electron in the opposite direction then the Hall effect shouldn't have shown positive hall voltage.
vin300 said:If B is along +ve z and either velocity of holes is in +ve x or velocity of electrons is in -ve x, Hall voltage is +ve.
If B is along +ve z and either velocity of electrons is in +ve x or holes in -ve x, Hall voltage is -ve
thecritic said:If the movement of holes were actually movement of electrons, then should always find -ve hall voltage (Right Figure) . Shouldn't we?
DrDu said:Maybe you should take into account that electrons at the upper end of the band have a negative effective mass. Hence a hole (the absence of one of these electrons) has a positive mass.
Studiot said:In post#6 you have a contradiction.
The derived force vector is correct in the right hand diagram but should be reversed in the left one as positive and negative charges are deflected in opposite directions.
Its a great relief to hear that.Studiot said:Your diagram in post 6 is both correct
thecritic said:I don't think that's correct. Look at the following illustration I sketched
This is explaining how conduction begins, Right?Studiot said:The lattice is electrically neutral. So if we take a negative electron from point A and shove it over to point B, point B becomes –1 negative and this leaves a corresponding +1 positive charge at point A, supplied by the positive charges in the area that were formerly balancing the -1 charge on the electron we have moved.
This is explaining how conduction continues.Studiot said:However, once the hole and electron have separated (ie the pair has been 'created') there is nothing in the model to continue to link a particular hole to a particular electron. If the electron moved on again to point C it would not leave another hole at B, just a neutral point.
Equally the hole could move by ‘displacing’ a different electron, or if you like a different electron could occupy point A which would again be neutral, leaving a +1 hole somewhere else in the lattice.
Studiot said:Now we know that all charges, holes and electrons, moving as part of the current, are subject to the leftwards Lorenz force.
So a leftwards movement of the hole at point A can be accompanied by a rightwards movement of electrons without violating any laws.
If the current is in upward direction, No matter how you try to explain the phenomenum, The net electron flow must be in downward direction, Right?
3. If the elctron flows in downward direction, then Lorentz Force pushes it left, and Hence
-ve Hall Volatge, Right?
But all other electrons in the lattice are not subject to this force as they are not moving as part of the current. And there are plenty available.
etc
Yes, I am aware of that.Studiot said:(You are aware that the force you have labelled 'Thrust' is called the Lorenz Force?)
I am aware of that too.Studiot said:Don't forget there are no electrons moving directly leftwards. These are the ones whose trajectory has two components, viz the upward flow of current and the leftwards push, resulting in a path curving towards the left.
Then which electrons are they? And which force causes them to move rightwards?Studiot said:The electrons that need to move rightwards are not the electrons that take part in the upward flowing current.
Consequently they are not the ones being forced leftwards by the Lorenz force.
DrDu said:Ok, here's my view:
ma=qE+q vxB
is the equation of motion. Due to friction, the acceleration will lead to an equilibrium velocity v that will show in the same direction as the acceleration a.
Case a: m>0, q<0 (electrons at the lower end of the band)
v is antiparallel E, j =q v is parallel E. If E is in x-direction and B in z-direction, then the electrons will be deflected in direction of -y.
Case b: m<0, q<0 (electrons at the upper end of the band with negative effective mass)
v is parallel E, j is antiparallel E. If E is in x-direction and B in z-direction, then the
electrons will be deflected in direction of -y, as in case a. However, as the direction of the current is reversed in comparison with case a, the hall coefficient will be of alternate sign.
case c) m>0, q>0 (holes):
v is parallel E, j is parallel E and holes are deflected in direction of -y. The Hall coefficient equals the one in case b.
