What is a phase map and how is it used in structured light 3D scanners?
  • Context: Graduate
  • Thread starter Thread starter ahkcasfm
    Map Phase
A phase map in the context of structured light 3D scanners refers to a representation of the surface geometry of an object, derived from the analysis of sinusoidal light patterns projected onto the object. The process involves capturing images with a camera and utilizing software to extract a 3D model by comparing the acquired phase map to a reference phase map. This technique is essential for accurately measuring surface shapes and depths in 3D scanning applications.
  • Understanding of structured light 3D scanning techniques
  • Familiarity with digital fringe projection methods
  • Knowledge of Fourier Transforms and their applications
  • Basic principles of differential equations and their graphical representations
  • Research the algorithms used for phase map extraction in structured light 3D scanners
  • Explore software tools for processing images from digital fringe projection
  • Learn about the calibration techniques for reference phase maps
  • Investigate the impact of different sinusoidal patterns on phase map accuracy
This discussion is beneficial for optical engineers, 3D scanning professionals, and researchers involved in surface measurement and modeling using structured light techniques.
ahkcasfm
What is a "phase map"?
I am doing some reading on Structured Light 3D Scanners using digital fringe projection, where a projector shines light (e.g. sinusoidal patterns) onto an object, a camera takes some pictures, and some software uses them to extract a 3D model of the object.
The papers I have been reading talk about acquiring a "phase map" of the surface and comparing it to a "reference phase map". None of them seem to actually define what this means, and searching on Google seems to just give links to papers.
Here is an example: http://www.cadanda.com/V2No6_04.pdf (ctrl-F "phase map" will give plenty of results)
Can anyone explain in relatively simple terms? I have quite a good understanding of time/frequency domain, Fourier Transforms, etc. but have never heard this term before.
Mathematics news on Phys.org
A "phase map" for a differential equation is a graph consisting of short line segments showing, at each point (x,y), the slope of the function y= f(x), satisfying the differential equation and passing through the given point. Actual solutions to the differential equation will be tangent to those line segments so the phase map can show properties of solutions even if you cannot solve the equations.
Hmmm ... so in the context of measuring surface shape, would the phase map be a table of values (one for each pixel) giving the slope of the depth function (z = f(x,y))? Or perhaps the slope in a particular direction (probably the x direction)?
Thanks
  • · Replies 34 ·
  • · Replies 20 ·
  • · Replies 0 ·
