What is a recombination ionization chamber?
The discussion centers on the concept of recombination in ionization chambers, particularly the specialized "recombination chamber." Recombination is typically detrimental, especially for neutron and alpha radiation due to their dense ionization trails, which necessitate higher voltages to mitigate recombination effects. The recombination chamber, however, utilizes recombination to measure quality factors of unknown radiation fields by analyzing the slope of recombination at varying voltage levels. This method is particularly relevant for applications in radiation protection, especially around pulsed radiation sources.
  • Understanding of ionization chamber operation and design
  • Knowledge of radiation types, specifically neutron and alpha radiation
  • Familiarity with high voltage (HV) applications in radiation detection
  • Basic principles of radiation dosimetry and quality factor (QF) calculations
  • Research the principles of ionization chambers and their operational characteristics
  • Study the effects of high dE/dx on recombination in ionization chambers
  • Explore the methodology for determining quality factors in radiation fields using recombination chambers
  • Investigate the impact of electronegative gases and impurities on ionization chamber performance
Radiation physicists, dosimetrists, and professionals involved in radiation protection who seek to understand the implications of recombination in ionization chambers and its applications in measuring radiation quality factors.
DragonPetter
I have been under the impression that recombination is a bad thing, not a good thing. And you increase your voltage on an ion chamber until recombination is eliminated. I also understand that recombination is a bigger problem for neutron and alpha radiation because its ionization trail is much denser (and leaves a column of ions), and since the ionization happens so densely, the ions and electrons are very close together such that their electric field attraction is much greater, and so the electric field of the ion chamber must be much higher to overcome this dense column from recombining.
So, I am curious what a recombination chamber is. Does it use recombination for some measurement purpose? How could recombination be a desired effect in an ion chamber?
Edit: I tried researching online, but the only article I could find that looked helpful required a purchase, and it was expensive with no guarantee of answering my question.
Recombination in ion chambers is generally a bad thing that adversely affects their operation. There are several causes of recombination in ion chambers and proportional counters
1) Dense track (high dE/dx) recombination
2) Volume recombination
3) Electronegative gases or impurities
4) Pulsed radiation operation; e.g., like pulsed neutron BF3 chamber
Raising HV generally reduces recombination loss, but often not possible in proportional chambers.
You might review this
http://books.google.com/books?id=WN...CEYQ6AEwAQ#v=onepage&q=boag dosimetry&f=false
or read chapter on ionization chambers by Boag in this book by Attix
http://books.google.com/books?id=r6BFAAAAYAAJ&dq=boag dosimetry&source=gbs_similarbooks
Hi Bob S,
thanks so much for your help.
I understand what you have said. I have come across a special chamber called a "recombination chamber". I actually have a better idea what it is after doing a better google search. This article explains:
http://www.irpa.net/irpa9/cdrom/VOL.4/V4_92.PDF
Its used to determine quality factors of unknown radiation fields by finding the "slope" of recombination from different voltage levels.
Interesting paper. It utilizes the collection inefficiency to get the quality factor (QF). Their gas is not TE (tissue equivalent; too much hydrogen). Because my interest is more in radiation protection around pulsed radiation sources, I would prefer measuring correct absorbed dose, with no dependence on either pulse duty factor or QF.
I am not sure what their Fig, 1 plot is measuring; QF for neutrons is maximum between 1 and 10 MeV.
I would have more confidence in method (1) than method (2). Their circuit diagrams are very incomplete.
  • · Replies 27 ·
  • · Replies 24 ·
  • · Replies 20 ·
10K
  • · Replies 25 ·
