What is causing error code 16492 in PSpice?
1 reply · 5K views · last reply
Louis Aguilar
Run a transient simulation and plot the three outputs, Vo(t), on the same plot. Use the following settings:
1. Set the Run Time (or Stop Time) so that you plot 3 cycles of Vo(t).
2. Set the Maximum Step Size so that you get at least 100 points per period for Vo(t).
3. Set the Y axis limits to 0 volts and 10 volts. Do not auto scale.
The model that you will use for the MOSFET is:
Id = (kp/2)(Vgs – Vto)2 (1 + lambda*Vds)
Kp = 0.01
Vto = 1
Lambda = 0.05
Given Circuit Design:
Three MOSFET common-source circuit schematics side by side, each with a 1k drain resistor to 10Vdc, a sine voltage source with VOFF 0, VAMPL 0.5 and FREQ 1k, and DC biases of 1Vdc, 2Vdc and 3Vdc.
I have attempted to do it in PSpice but I'm getting error code saying missing values, what am I doing wrong?
My Design:
PSpice schematic of three MOSFET common-source stages side by side, each with a 1k drain resistor to a 10Vdc supply and a gate driven by a DC bias source (1Vdc, 2Vdc, 3Vdc) plus a sine source with VOFF = 0, VAMPL = 0.3, FREQ = 1K.
My Simulation Profile:
PSpice Simulation Settings dialog for ee_241_hw, Analysis tab, Time Domain (Transient) selected, Run To Time 3m seconds, Maximum Step Size 250u seconds, Start saving data after 0 seconds.
Mosfet PSpice Model:
PSpice Model Editor Lite window showing the model text .model Mbreakn NMOS (VTO=1 KP=0.01 L=0.05) with a Models List entry Mbreakn of type MOS.
Error Code:
PSpice netlist excerpt with error ERROR(ORPSIM-16492): Missing value repeated three times, each after a +SIN source line such as +SIN 0 0.3 1K 0 0 0, with V_V5, V_V9, M_M1, V_V6, M_M2, R_R2, V_R3 and M_M3 entries listed.
Kp = 0.01
Vto = 1
Lambda = 0.05
My Design:
Error Code:
Welcome to the PF.
What does the manual say about that error 16492? Can you simplify the simulation down to just one circuit for now, and see if you can figure out what's missing?
