What is centre of gravity. How is it calculated?
The discussion revolves around the concepts of center of gravity and center of mass, including their definitions, calculations, and implications in physics. It touches on theoretical aspects as well as applications in mechanics, with some exploration into the behavior of subatomic particles like quarks.
  • One participant describes the center of mass as a point where the entire mass of a system can be considered to be concentrated, affecting gravitational interactions.
  • Another participant explains that the "effect" refers to gravitational force, using the example of the Earth-moon system to illustrate how center of mass simplifies calculations.
  • It is suggested that the center of gravity is equivalent to the center of mass in a uniform gravitational field.
  • A question is raised about the applicability of these concepts to quarks within protons, prompting a discussion on whether calculating the center of mass for quarks is valid in classical physics.
  • Some participants express uncertainty about their qualifications to answer questions related to quarks and the strong force, indicating a gap in knowledge regarding quantum mechanics.
Participants generally agree on the definitions and implications of center of mass and center of gravity in classical mechanics. However, there is no consensus on the application of these concepts to quarks, with differing levels of knowledge and uncertainty expressed regarding quantum mechanics.
Some limitations include the lack of clarity on how gravitational effects are modeled at the subatomic level and the dependence on classical physics definitions when discussing quarks.
chandran
centre of mass
There is a mass at a position vector r1 from origin. like wise there are different masses at different r from the origin. the
centre of mass is the distance in which the entire mass can be concentrated at some distance R which will give the same EFFECT as that of the original
system.
What is the effect we are talking about?
The "effect" would be related the gravitational force. When using Newton's Law of Universal Gravitation [tex]F = G\frac{m_1 m_2}{r_{12}^2}[/tex] to calculate the force between two objects you calculate the distance between the two objects [tex]r_{12}[/tex] as the distance between the center of masses of the two objects, no matter what shape the two objects posses.
For example, when calculating the gravitational force between the Earth and moon you do the calculation by regarding the entire masses of the Earth and moon as concentrated to two single points located at the center of masses of the Earth and moon. Here the original system is the real Earth-moon system and the "concentrated" system would be considering the Earth and moon as two points with the same masses as the Earth and moon concentrated at the center of mass of the two objects and the "effect" is the gravitational force, ie. it would be the same in both situations. I hope that makes sense.
The center of gravity and center of mass is basically the same thing. Its the average location of all the mass inside an object. You can read more about at http://en.wikipedia.org/wiki/Center_of_mass .
You can simplify matters by assuming that all mass of an object is contained at that point (centre of mass - CM) and you can evaluate the translatory motion of that object considering it as a point particle. This is what you generally do when solving problems in elementary mechanics, such as a car slowing down, a block sliding on a ramp, etc.
The centre of gravity(CG) is the nothing but the CM in a uniform gravitational field.
To Universal & Neutrino. Would your answer also apply to the three quarks found within the proton ? If not, how would one calculate the center of mass for these quarks--or is this even a valid question for a thread on Classical Physics ?
I don't think I'm qualified to answer your question, Rade, :smile:
Rade, your question is a little beyond my knowledge. I believe that quarks are subject to all the fundamental forces, including gravity which means that they have mass. I don't know enough about quarks to know if calculating the center of mass of three quarks is a valid thing to do.
More important than gravity to quark interactions is the strong force (which involves another property called color) which is the major mediating force between quarks. The theory of quark interactions via the strong force is called Quantum Chomodynamics (QCD), and I know next to nothing about this theory. You will probably get a better answer if you asked your question in the quantum forum.
  • · Replies 51 ·
  • · Replies 42 ·
  • · Replies 32 ·
