What is exponential distribution
Definition/Summary
The exponential distribution is a probability distribution that describes a machine that it equally likely to fail at any given time.
Equations
[tex]f(t) = e^{-\lambda t} \lambda[/tex]
Extended explanation
A machine is equally likely to fail at any given time. For any [itex]t[/itex], the probability of failure in the interval [itex](t, t + dt)[/itex] is [itex]\lambda dt[/itex]. So the probability that it doesn't fail in that interval must be [itex]1 - \lambda dt[/itex]
Let us calculate the probability that it doesn't fail in the interval [itex](0,t)[/itex]. Divide [itex]t[/itex] into [itex]n[/itex] equal parts. Each part then has size [itex]\frac{t}{n}[/itex]. The probabilities that it doesn't fail in the intervals [itex](0,\frac{t}{n})[/itex], [itex](0,2\frac{t}{n})[/itex], ... are
[tex]1 - \lambda \frac{t}{n}[/tex]
[tex](1 - \lambda \frac{t}{n})^2 ,[/tex]
... respectively. Therefore we find that the probability that it doesn't fail in the interval [itex](0,t)[/itex] is approximately
[tex](1 - \lambda \frac{t}{n})^n .[/tex]
The exact answer is the limit of the above expression as [itex]n \rightarrow \infty[/itex], i.e.
[tex]e^{-\lambda t}.[/tex]
We can now use this to find the probability density function [itex]f(t)[/itex] that it fails for the first time in the interval [itex](t,t+dt)[/itex]. Clearly, this is the probability that it doesn't fail in the interval [itex](0,t)[/itex] times the probability that it fails in the interval [itex](t,t+dt)[/itex].
[tex]f(t) = e^{-\lambda t} \lambda.[/tex]
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
The exponential distribution is often used as a model of the duration of random time intervals, such as
  • Time between two calls
  • Waiting time in a line
  • Longevity of atoms in radioactive decay
  • Lifetime of components, machinery and equipment when aging phenomena do not need to be considered
  • as a rough model for small and medium damages in households
  • motor vehicle liability
##\lambda## represents the number of expected events per unit interval.
