Miraj Kayastha
- 80
is GPE at a point the work we must do against the gravitational force to bring an object from infinity to the point? Or is it the work done by the gravitational force?
Gravitational Potential Energy (GPE) is defined as the work done on an object against the gravitational force to bring it from infinity to a specific point. This definition emphasizes that GPE is not the work done by gravity but rather the work required to oppose it. The discussion highlights the importance of sign conventions in physics, particularly in the context of energy conservation, where GPE and kinetic energy are related. The concept of GPE is crucial for understanding gravitational interactions and energy transformations in physics.
PREREQUISITESStudents of physics, educators teaching mechanics, and anyone interested in the principles of energy and forces in gravitational contexts.
Yes.Miraj Kayastha said:is GPE at a point the work we must do against the gravitational force to bring an object from infinity to the point?
No, it's the negative of that.Or is it the work done by the gravitational force?
Miraj Kayastha said:is GPE at a point the work we must do against the gravitational force to bring an object from infinity to the point? Or is it the work done by the gravitational force?
sophiecentaur said:It has to be the work done ON. The Force could be due to many causes - a spring and gravity, for instance. How would you apportion the work done BY between the two, if it worked your alternative way? If you read the definition anywhere, it is quite consistent.
jbriggs444 said:What point are you trying to make here? That gravitational potential energy is equal to the work done ON an object to oppose gravity rather than the work done ON an object by gravity amounts to nothing more than a sign convention.
We adopt the sign convention that we do so that "Kinetic Energy" plus "Gravitational Potential Energy" is conserved.
One could equally well adopt the opposite sign convention so that "Kinetic Energy" minus "Gravitational Energy Deficit" is conserved.
sophiecentaur said:I was just pointing out that using the definition avoids any confusion (of sign, as you say). If you start introducing the idea that gravity 'does work' when things fall then there can be utter confusion if and when there is another agency involved. I think that is a valid point and is not just a matter of a sign.
jbriggs444 said:If gravity is modeled as a force then gravity does do work when things fall. If two forces are applied to a moving object then both forces do work. That there can be confusion does not change the facts of the matter.
sophiecentaur said:The question was about Gravitational Potential. I thought that was defined in terms of Work done ON a unit Mass to bring it from infinity. Isn't that the fact of the matter? I can't see a need to consider who does the work so why is there a need to worry further?
