What is meant when someone says 50% solution of NaCl?
  • Thread starter Thread starter mikepl1
A 50% NaCl solution refers to a weight/volume (w/v) percentage, meaning it contains 50 grams of NaCl dissolved in 100 mL of water. Conversely, a 35% ethylene glycol solution indicates 35 mL of ethylene glycol mixed with 65 mL of water, totaling 100 mL of solution. It is important to note that while volumes do not add perfectly, for laboratory purposes, minor discrepancies are generally acceptable. The distinction between weight/volume (w/v) and volume/volume (v/v) percentages is crucial for accurate solution preparation.
  • Understanding of solution concentration terminology (w/v and v/v)
  • Basic knowledge of laboratory measurement techniques
  • Familiarity with common laboratory solvents (e.g., NaCl, ethylene glycol)
  • Concept of solution preparation and dilution
  • Research the differences between weight/volume (w/v) and volume/volume (v/v) concentrations
  • Learn about the preparation of standard solutions in laboratory settings
  • Explore the impact of temperature on solution volume and concentration
  • Study the principles of solution chemistry and solute-solvent interactions
Chemistry students, laboratory technicians, and professionals involved in solution preparation and analysis will benefit from this discussion.
mikepl1
when someone talks about a 50% NaCl solution or a 35% ethylene glycol solution, what does this really mean? Is this the percentage of the solute in the solution by mass, moles, or what?
Thanks.
Chemistry news on Phys.org
Thanks.
Depends if you see v/v (volume/volume) or w/v (weight/volume) %. 50% (w/v) NaCl would be 50 grams in 100 mL of water. 35% ethylene glycol would be 35 mL ethylene glycol + 65 mL water = 100 mL solution, but 35% of that solution is ethylene glycol.
In reality volumes don't add, but 99% of the time for lab purposes it doesn't matter if you're off by 0.01 mL.
I always interpreted that to be 50 grams of NaCl in 100 mL of solution (solution = water + salt).
  • · Replies 21 ·
