What is the formal definition of spacetime in physics?
  • Context: Graduate
  • Thread starter Thread starter Enrico
    Spacetime
The discussion centers on the formal mathematical definition of spacetime in physics, exploring its structure as a manifold and the implications of different metrics in General and Special Relativity. Participants delve into the nature of events within spacetime and the concept of equivalence among them, as well as the significance of coordinate charts.
  • Some participants define spacetime as a pseudo-Riemannian manifold with a specific signature, while others describe it as a pair consisting of a manifold and a locally Lorentzian metric.
  • There is a discussion about whether all events in spacetime are mathematically equivalent or if there exists a privileged '0' element, with some arguing that all events are equivalent in the manifold structure.
  • One participant suggests that in Special Relativity, spacetime is essentially R4, implying that the point (0,0,0,0) holds special significance.
  • Another participant counters that the assignment of (0,0,0,0) as a special point is arbitrary and does not confer any physical significance.
  • Different perspectives on the nature of manifolds are presented, with one participant asserting that not all manifolds are isomorphic to R4, using the example of a sphere to illustrate their point.
  • Participants discuss the implications of choosing a coordinate chart and how this affects the perception of special points within the manifold.
  • References to literature, such as Carroll's lecture notes, are provided to support the discussion on manifolds and coordinate charts, particularly in the context of Special Relativity.
Participants express differing views on the equivalence of events in spacetime and the significance of the '0' element, indicating that multiple competing views remain unresolved. There is no consensus on whether a privileged frame of reference exists.
Limitations include varying interpretations of equivalence among events, the dependence on definitions of manifolds, and the unresolved nature of the mathematical implications discussed.
Enrico
Dale said:
A coordinate chart is a smooth and invertible mapping between events in spacetime and points in R4.
What is the mathematical definition of spacetime here?
Mathematically, spacetime is a pseudo-Riemannian manifold with signature (-+++)
A pair ##(M, g_{ab})##, where ##M## is a manifold and ##g_{ab}## is a locally Lorentzian metric on ##M##.
@Dale @PeterDonis Your answers are actually the same thing, right? I think I grasp the concept, although I never got a systematic training on manifolds (this is differential geometry, isn't it?).
But I have a concern. In this definition, are all events mathematically equivalent, or is there some privileged '0' element?
Yes.
Yes.
All events are equivalent as far as the manifold structure is concerned. The spacetime geometry at different events might be different because the metric can vary from event to event.
This in General Relativity, right? However, this is not what I have in my mind. My point: I presume a manifold is, as a set, a subset of some Rn space. If this is correct, not all of its elements are algebraically equivalent. In Special Relativity, spacetime would be substantially R4, to my understanding. But then there is a '0' element which has a special meaning, again algebraically.
I'm sorry for the bad wording, due to my lack of knowledge of differential geometry. To be clear, I'm thinking of a coordinateless definition of spacetime similar to what is done for affine spaces.
Yes. In Special Relativity, the metric is the same everywhere (the flat Minkowski metric) and the manifold is ##R^4##.
Not the way you mean. See below.
Wrong. All points in Minkowski spacetime (the flat spacetime of SR) are equivalent. Choosing a coordinate chart arbitrarily picks one of the points as an "origin", but you do not need to choose a coordinate chart in order to work with Minkowski spacetime.
You have said you are not familiar with differential geometry. I strongly suggest learning the basics of it instead of trying to speculate on your own.
And that is exactly the kind of definition @Dale and I gave you. Your speculations that that is not the case are mistaken.
Not only is there no privileged 0 element, a manifold is not even an affine space. So you cannot make it into a vector space by artificially picking a privileged 0 element.
I don’t know what you mean by “equivalent” in this context. However, not all manifolds are isomorphic with R4.
As a counter example, consider a 2D manifold like a sphere. If you remove a single point from a sphere then it is isomorphic with R2 and can be covered with a single chart. But with that point it requires at least 2 charts to cover the whole manifold and so the manifold is not isomorphic to R2.
PeterDonis said:
In Special Relativity, the metric is the same everywhere (the flat Minkowski metric) and the manifold is R4.
R4 contains (0,0,0,0), which looks to me as a special element, hence my questions. However, I'll stop speculating. May you please provide me with a reference for the definition of manifold and coordinate chart, having in mind Special Relativity in particular?
The method you use to assign the label (0,0,0,0) to a particular event is arbitrary (you change it every time you zero a stopwatch), so that event can't be special in any physical sense.
There is a conventional sense in which that event is special. If everybody agrees to use the same event as the origin then the transform of that event's coordinates is always trivial, however outré the rest of their coordinate system. But you don't have to do that if you like unnecessary algebra.
In GR spacetime is by assumption a pseudo-Riemannian space with signature (1,3) or (3,1), depending on your sign convention (west vs. east coast), also known as a Lorentzian manifold. That's the amalgamation of the vague discussions about the "equivalence principle" to a clear mathematical statement. Physically it means that at any event you can define a local inertial frame of reference, where the local (and only the local) special-relativistic laws hold.
Another approach, more attractive for particle physicists, is to make Poincare symmetry local. This leads for the usual macroscopic (astronomical/cosmological) situations, where you only have scalar and the electromagnetic fields (hydrodynamics and electromagentic interactions) to GR. For inclusion of spin it leads to an extension of GR, called Einstein-Cartan theory, where the spacetime has also torsion.
Given an infinite featureless plane, can you locate its center?
If we scattered ten people randomly on that plane [one at a time, with no communication among them],
would they choose a distinguished point?
(Given a sphere [the surface of a featureless non-rotating Earth in otherwise empty space], can you locate a special point on it?)
You could certainly choose a point of reference and maybe a set of axes for reference,
but that choice is arbitrary.
Many measurements you make and calculations based on those measurements will depend on those choices.
However, the more interesting "physical quantities"
are those measurements and calculations that agree with
others doing analogous measurements.
Only if you put a coordinate chart on it. The manifold ##R^4## by itself, without a coordinate chart, does not have any particular mapping of points in the manifold to 4-tuples of real numbers, so there is no particular point that has the numbers (0, 0, 0, 0).
You probably won't find one that is focused on SR in particular, because in SR these concepts are often glossed over.
Carroll's online lecture notes on General Relativity include a good introduction to manifolds as the concept is used in GR:
https://arxiv.org/abs/gr-qc/9712019
I second the reference to Carroll’s lecture notes. The first two chapters cover this topic with a focus on special relativity. After that then the rest of the book is focused on general relativity.
@Ibix @vanhees71 @robphy You all seem to rephrase exactly what I have in my mind, i.e. that, physically, there is no privileged frame of reference. However, if we want to have a precise algebraic definition of spacetime (i.e. an algebraic construction where events are elements of a set that is constructed from previously known mathematical entities, such as ##\mathbb{R}^4##), with no privileged events, how do we proceed? In a "static" 3D plane, one may go with an affine space, but how do we include the relativity of velocity?
What I ask of course is based on the assumption that spacetime is a physically meaningful concept, a priori from any frame of reference or measurement, and on my feeling that we need to have a mathematical model for it, where by mathematical model I don't mean just outlining its properties, but actually constructing the abstract entity, as it is usually done in algebra, from already defined concepts.
Enrico said:
if we want to have a precise algebraic definition of spacetime (i.e. an algebraic construction where events are elements of a set that is constructed from previously known mathematical entities, such as R4), with no privileged events, how do we proceed?
Read the first two chapters of the Carroll reference. That is covered in sufficient but not excessive detail.
PeterDonis said:
Only if you put a coordinate chart on it. The manifold R4 by itself, without a coordinate chart, does not have any particular mapping of points in the manifold to 4-tuples of real numbers, so there is no particular point that has the numbers (0, 0, 0, 0).
That's my algebraic concern: so how is the manifold ##\mathbb{R}^4## defined? Is it an actual algebraic entity, or a primitive concept where you only state its properties?
And this is what I don't like at all, since it leads to misunderstandings (already happened to me in the past).
@PeterDonis @Dale Thanks for the reference, I'll dig into that and see whether I can find there the answers I'm looking for.
Enrico said:
@Ibix @vanhees71 @robphy You all seem to rephrase exactly what I have in my mind, i.e. that, physically, there is no privileged frame of reference. However, if we want to have a precise algebraic definition of spacetime (i.e. an algebraic construction where events are elements of a set that is constructed from previously known mathematical entities, such as ##\mathcal{R}^4##), with no privileged events, how do we proceed? In a "static" 3D plane, one may go with an affine space, but how do we include the relativity of velocity?
Many such statements can be reformulated geometrically, often in analogy with Euclidean geometry.
On a plane [of course, featureless and infinite in extent],
there is no privileged set of coordinate axes or coordinate-systems.
If I read you correctly, "the relativity of velocity" is akin to choosing one axis
to be like the x-axis of a sheet of graph paper.
You can certainly assign coordinates to things (like points on lines and on circles).
But your assignments are only meaningful together with your choice of axes.
With all of the information, one can compare similar measurements from other observer/surveyor choices.
An interesting calculation common to all choices of graph paper orientations
is the squared-separation between two specific points P and Q: ##\Delta x^2+\Delta y^2##.
While many surveyors will have different values of ##\Delta x## among themselves, and ##\Delta y##,
they will all agree on ##\Delta x^2+\Delta y^2##.
Such quantities are examples of invariants.
Since the quantity is independent of the choice of graph-paper orientation,
that quantity is more about the object being described
(and less about the surveyor measuring the object).
What do you mean by "an actual algebraic entity"? Do you have a reference for this term? And why are you so concerned about it?
A quick version of the definition Carroll gives is that a (4-dimensional) manifold locally "looks like" ##\mathbb{R}^4##. As Carroll notes, ##\mathbb{R}^4## itself obviously meets that definition since it "looks like" ##\mathbb{R}^4## not only locally but globally.
However, there is a subtlety here. When we say a 4-dimensional manifold locally "looks like" ##\mathbb{R}^4##, what we are saying, heuristically, is that we can pick any point in the manifold and treat it like the origin of ##\mathbb{R}^4##, i.e., the point with coordinates (0, 0, 0, 0). And since ##\mathbb{R}^4## itself is a manifold, this is saying that when we consider ##\mathbb{R}^4## as a manifold, we can pick any point as the origin. Which means the manifold definition of ##\mathbb{R}^4## can't pick out any particular point as the origin; it has to allow any point to be chosen as the origin. That's why, even though ##\mathbb{R}^4## is usually defined as "the set of 4-tuples of real numbers", it does not have any "privileged" origin point, even though there is a particular 4-tuple of real numbers, (0, 0, 0, 0), that looks "privileged".
There might be a more sophisticated formal mathematical definition of "manifold" that explicitly takes the above into account, so that it would give a definition of ##\mathbb{R}^4## that does not depend on any explicit realization as 4-tuples of real numbers. However, to find such a definition you would probably have to look in a math textbook, not a physics textbook. Physicists are generally not concerned with such fine points; for a physicist, the manifold definition Carroll gives is sufficient, even though it leaves issues like the one described above without any formal resolution.
I'm trying to expose my thoughts, sometimes I cannot find the right words. Let me try again.
If we talk about ##\mathbb{R}^4##, the concept is clear: set of 4-ples of real numbers (i.e. applications from {1,2,3,4} to ##\mathbb{R})##, where ##\mathbb{R}## is defined by (if I recall right, it's more than 20 years since my last take on this) a procedure by Dedekind. So it's clear what an application from ##\mathbb{R}^4## to ##\mathbb{R}^4## is.
But if we talk about an application from a 4-dimensional flat manifold to ##\mathbb{R}^4##, how do we define the former? Is there an analogous algebraic procedure? Again, I'll look into Carroll's lectures, I have already printed out the first two chapters.
I think that if the concept of spacetime is not clearly defined, there's room for misunderstanding (again, already occurred to me).
  • Skeptical
I have only read this after my last reply. Here you get exactly my point.
(And from what you say I understand that I won't find the definition I'm looking for in Carroll's notes.)
It might be helpful if you give details about your mathematical viewpoint and goal.
In the typical discourse on relativity and differential geometry, one doesn't make reference to Dedekind.
Before moving into the spacetime structure in relativity,
it might be better to first think in terms of
the geometry of the plane ##R^2##,
then maybe move on to the geometry of the sphere ##S^2## (the surface of a ball).
What is your viewpoint on these structures?
(Are you looking for an axiomatic development of a manifold?)
I've been trying to do so.
That was just an example to clarify what kind of procedure I have in my mind. In Special Relativity I'd think of something like "a point in space is the equivalence class of all its possible coordinatisations in inertial frames". Just a naive idea, nothing else.
Or even in one single dimension. If we don't take velocity into account, but just relative position, the solution is an affine space.
For now I content myself with flat spacetime.
As said above.
Not axiomatic, but constructive. My understanding of axiomatic would be as saying that a manifold is a primitive concept and only defining its properties.
I want to add something at this point: last Winter I discovered the work of T. Matolcsi about mathematical definition of coordinateless spacetime. I had started reading but stopped at some point. Sooner or later I'll start again. That's a promising approach but I'm surprised I can't find any other similar trial around.
Unfortunately I don't seem to be able to find a free pdf online. The book is sold here:
https://www.amazon.com/dp/1927763940/?tag=pfamazon01-20
(Shorter papers on applications of this approach may be found on arXiv: see, e.g., https://arxiv.org/abs/math-ph/0611046)
"Constructive" still has to start from some axiomatic foundation. What foundation are you proposing to start "constructive" from?
Same as for foundations of Maths? I'm not an expert in that in any way, but my understanding is that if you give the Naturals and the concept of Set as primitive concepts, you may build up everything from there.
Once you get to the Reals, you should proceed from there, without introducing further primitive (axiomatic) concepts.
  • Skeptical
  • Sad
This sounds like "Theory of Measurement" ...
although as @PeterDonis says there must some foundation ["axiomatic' or not].
What primitive elements are you equipped with?
For example
...and likely many others.
But whatever it is,
while interesting and thought-provoking -- in principle,
such a discussion will likely be quite involved and move rather slowly,
and probably needs to be in another thread.
No. There is no single "foundations of math"; different foundations are used for different purposes.
You can build up all of the different number systems from there (natural numbers, integers, rational numbers, real numbers--and onward to complex numbers if you like). But "math" is a lot more than just number systems.
I'll be curious to see if you still think this after you have taken the time to read through Carroll's presentation.
In an affine space there's no distinguished point, i.e., the space is translation invariant. If you describes points by a vector you arbitrarily specify one point (the "origin") and a basis of the vectorspace to define a reference frame and then calculate with the "position vectors", which then uniquely map to each point of the manifold. You can, of course, choose any other point as the origin and any other basis of the vector space, and the corresponding transformations must be symmetry transformations of the equations you derive. Everything that has a geometric meaning must be expressible in terms of invariants, i.e., scalars, vectors, and tensors. If you define a (classical or quantum) field theory you can also have "objects" which are defined via some representation of the affine space's symmetry (e.g., spinors in Minkowski space).
One could proceed by the familiar mathematical process of taking an equivalence class. Two "manifolds plus metric" are equivalent if there is a metric-respecting isomorphism between them.
Then instead talking about a spacetime being a manifold plus metric, one can talk about a spacetime as being an equivalence class of manifolds-plus-metrics.
I do not imagine that many physicists are particularly concerned with the fine distinction between talking about an equivalence class versus talking about an exemplar of that class when trying to compute invariants.
All experimental results are invariants.
  • · Replies 51 ·
  • · Replies 38 ·
  • · Replies 37 ·
  • · Replies 58 ·
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 39 ·
