What is St. Elmo's fire enrgy source?
  • Context: Undergrad
  • Thread starter Thread starter Stanley514
    Fire Source
St. Elmo's fire is a phenomenon that produces light through electrostatic energy, ultimately sourced from the Sun. The discussion clarifies that this light can be generated without a current flowing, as the strong electrical field can separate electrons from their atoms, creating a mixture of charged particles. While some participants debate the usefulness of this energy, it is established that even minimal energy output can be considered useful, such as powering a pocket calculator. The energy generation process involves friction stripping and moving electrons, similar to static electricity.
  • Understanding of electrostatics and electric fields
  • Knowledge of light generation mechanisms
  • Familiarity with energy conversion principles
  • Basic concepts of static electricity and charge separation
  • Research the principles of electrostatics and their applications
  • Explore the mechanisms of light generation in electric fields
  • Study energy conversion techniques, particularly from light to electricity using photocells
  • Investigate the role of thunderstorms in atmospheric electricity phenomena
Physicists, electrical engineers, educators, and anyone interested in atmospheric phenomena and energy generation principles.
Stanley514
Simon Bridge said:
It's electrostatic ... ultimately from the Sun.
http://science.howstuffworks.com/nature/climate-weather/atmospheric/st-elmo-fire1.htm
The passage in wikipedia you quoted actually tells you where the energy comes from...
I thought that in order to obtain useful energy, a current should flow. Yet, according to their description all this phenomenon happens before conditions for lightning are completely created. In my opinion a simple static field cannot generate an energy to do a work...
Where are you getting the idea that this can generate "useful" energy/work? Or that it happens before there is a significant charge separation?
That's not right - you can get light without any current flowing if you can just move enough charged particles around enough. The electrical field is quite strong enough to separate electrons from their parent atoms leaving us with a mixture of negative-charged electrons and positive-charged ionized atoms. Thermal motion in tis sea of charged particles then generates light.
Stanley514 said:
flow.
Basically? Your thought on this matter is mistaken.
Unfortunately Nature does not care about opinions, yours or mine.
Have you never seen a demonstration where a florescent light glows in an electric field, with no current passing through it?
http://techtv.mit.edu/collections/p...uorescent-and-neon-tubes-in-an-electric-field
Well, if there is a lights, we could convert this light into electricity with help of photocell and make it some useful work to do.
Sure, but very, very little. I'm not sure it could generate enough to call it "useful". Still, again, this doesn't imply a conservation of energy issue. I'm not seeing a problem here.
Even amount of energy sufficient to power a pocket calculator is useful. I wanted to know when it came from. Is there a changes in electric field?
Your article alludes to the source being the thunderstorm, but more specifically it is friction stripping and moving electrons around. Similar to when you shuffle your feet on a carpet:
http://scijinks.jpl.nasa.gov/lightning/
  • · Replies 22 ·
  • · Replies 74 ·
  • · Replies 16 ·
