What is the Accretion Rate of Earth?
The discussion revolves around estimating the accretion rate of inter-planetary dust by Earth, focusing on the particle number density, mass density, and relative velocity of the particles. The original poster presents a calculation attempt and seeks clarification on the methodology and assumptions used in the problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to model Earth as a flat circle moving through a dust cloud and calculates the mass gained per year based on this model. Some participants question the appropriateness of this model and the assumptions regarding particle density and mass.
Participants are actively engaging with the original poster's calculations, providing corrections and suggestions for refining the approach. There is a focus on clarifying the definitions of particle density and mass, as well as the implications of the radius of the particles. Multiple interpretations of the problem are being explored, and guidance has been offered to adjust the calculations based on corrected values.
There are discussions regarding the use of specific values provided in the problem statement, including the density of dust particles and the number density, which some participants note have not been fully utilized in the original calculations. The original poster expresses uncertainty about the validity of their approach and the assumptions made.
interdinghy
i) Estimate (in kg/yr) the rate of Earth accreting inter-planetary dust.
Assume a particle number density of n=1e-8/m3, a particle mass density of 5 gm/cc, a particle radius 50 microns and a relative velocity equal to Earth's orbital velocity (so the dust particles are, on average, at rest with respect to the Sun -- which would be expected if dust were deposited by long period comets with a uniform distribution of inclinations.
ii) How many years would it take Earth to increase its mass by 50%?
I talked with my professor and he told me to consider a flat circle moving through the cloud, and he said it would gain a certain amount of pass per second, then to consider the volume of the cylinder it would make.
Doing this, I found the area of a circle with the radius of the Earth to be about 1*10^8 km^2 accounting for significant figures. Then to make it a cylinder, I multiplied by an unknown height h in kilometers.
Next I multiplied this by the particle mass density:
[itex](1×10^{8})(h)km^{3} × 5 g/cm^{3}[/itex] and got [itex]5×10^{23}[/itex] grams
I looked up the speed at which Earth is orbiting the sun, and found it to be [itex]9.398×10^{8}[/itex] km/year, so I set [itex]h = 9.398×10^{8}km[/itex] and plugged it into what I had.
My final answer was that Earth accrued [itex]5×10^{29}[/itex] kilograms of mass per year and this is just ridiculous.
I don't think it's right to view the Earth in this problem as a flat circle, and I definitely don't see how it's right to see the volume it creates as a cylinder since the Earth isn't moving in a perfect straight line all the time. Also, he gave two values that I never used, so I'm sure I'm doing something wrong there too.
Can someone maybe clear up what he was trying to tell me or explain a better way to approach this problem?
Thanks.
5g/cm^3 is the density of the dust particles, not the density of material in your volume.
The flat circle for Earth is fine, but you have to consider the low density of dust particles and their small mass.
That last should be 5×1023g/m × h.
Your methodology is sound, but your density is wrong. The density you're given is typical for the density of a rock - or a piece of rock dust. There are also two pieces of information you haven't used - a radius and the number of dust grains per cubic meter. Can you put them all together?
So would it be right to say that since the particle number density is [itex]100cm^{-3}[/itex]:
[itex]\frac{m}{v} = \frac{5g}{1cc}[/itex]
Then there must be 5 grams of mass per 100 particles? That gives .05g per particle which is different but I don't think that completely fixes the answer, and I still can't see where I'd need the radius of the particles.
The number density tells you that there are 100 particles per cubic centimeter, yes. But what is the mass of an individual particle? Hint: they're almost certainly pretty close to spherical.
then is this right?
[itex]\frac{4}{3}\pi r^{3} = \frac{4}{3}\pi 50\mu m^{3}[/itex]
[itex]= 5×10^{-7}cc[/itex]
[itex]\frac{5g}{1cc} = \frac{xg}{5.0×10^{-7}}[/itex]
[itex]x = 5×(5.0×10^{-7})[/itex]
[itex]x = 2.6 × 10^{-6}g =[/itex] the mass per particle
Because this seems a lot more like what the mass of a particle should be.
Looks good. Carry on...
Then I'd adjust the mass to [itex]3×10^{-6}[/itex] and do what I was doing before,
particle number density × mass per particle
[itex](\frac{1×10^{17}}{km^3}) × (3×10^{-6}g)[/itex]
[itex]= \frac{0.3kg}{m^3}[/itex] the amount of mass the Earth gains per [itex]m^{3}[/itex]
Then I multiply this by the volume of the Earth-cylinder
[itex]1×10^{14}(h)m^{3} × \frac{0.3kg}{m^3}[/itex], h becomes unitless
[itex]= 3×10^{13}(h) kg[/itex]
to make it for a year, I use the orbital speed from my first post, to get
[itex]h = (9.398×10^{8})[/itex]
[itex]3×10^{13} × (9.398×10^{8}[/itex]) = [itex]3×10^{22}kg[/itex] rounded for sig digits. This still seems incredibly high?
The particle number density is 10/km^3 not 1*10^17. (it was 1e-8/m^3 not 1e8)
This change gave me [itex]3,000,000 \frac{kg}{yr}[/itex] adjusting for sig. figures, which is a much more believable answer.
Doing the math for part ii tells me that it'll take ~[itex]10^{18}[/itex] years for the Earth to increase its mass by 50%, a much less worrisome time frame.
Thank all of you for your time.
  • · Replies 16 ·
