What is the average force exerted on the putty by the surface?
The average force exerted on a 0.43 kg piece of putty dropped from a height of 2.8 m, which comes to rest in 0.22 seconds upon hitting a flat surface, is calculated using the impulse-momentum theorem. The correct approach involves determining the velocity just before impact using the kinematic equation v² = v₀² + 2ax, yielding a velocity of approximately 7.4 m/s. The average force is then calculated as F = ΔP/Δt, resulting in a force of -27 N, indicating the direction of the force is opposite to the motion of the putty.
  • Understanding of kinematic equations, specifically v² = v₀² + 2ax
  • Familiarity with the impulse-momentum theorem
  • Basic knowledge of Newton's second law (F = ma)
  • Concept of energy conservation in mechanical systems
  • Study the impulse-momentum theorem in detail
  • Learn about kinematic equations and their applications in free fall
  • Explore energy conservation principles in physics
  • Practice problems involving forces and time intervals in dynamics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of applying kinematic equations and the impulse-momentum theorem in real-world scenarios.
*intheclouds*
A 0.43 kg piece of putty is dropped from a height of 2.8 m above a flat surface. When it hits the surface, the putty comes to rest in 0.22 s. What is the average force exerted on the putty by the surface?
F\Deltat=\DeltaP
F\Deltat=mvf-mvi
\DeltaP=mvf-mvi
(I don't think it is a collision, but if it is...any of those equations also)
2.8m=(.22s)vo+.5(-9.8)(.22s)2
vo=13.8m/s
(.22s)F=(.43kg)(0m/s)-(.43kg)(13.8m/s)
F=-27N
But I know this isn't right...I just don't know what I did wrong...
*intheclouds* said:
A 0.43 kg piece of putty is dropped from a height of 2.8 m above a flat surface. When it hits the surface, the putty comes to rest in 0.22 s. What is the average force exerted on the putty by the surface? ...
Energy conservation to the surface, then kinematics.
U_0+K_0=U_f+K_f\rightarrow U_0=K_f, and
F=ma=m\Delta v/\Delta t...
the .22s is how long the putty takes to come to a stop AFTER it hits the ground, not the time it takes from when it was released.
How can you find the velocity of the putty JUST BEFORE it hits the ground?
HINT: Use one of the kinematic equations that does not involve time.
Casey
Am I going to use the equation:
v2=v02+2ax??
Then it would be 0=v02+2(-9.8)(2.8).
Vo= 7.4 m/s
Is that what you are looking for?
v2=v02+2ax??
Vo= 7.4 m/s
You're right for a start; here's my logic:
U_0=K_f
Because it starts at rest, 2.8m above the ground, we know:
U_0 = mgh = 11.8 J = mv^2/2 \rightarrow v = 7.41 m/s
Then,
v_f=v_i+at\rightarrow a=. Because force and acceleration are related, you can continue from here.
v2=v02+2ax??
Vo= 7.4 m/s
I am not sure why you are solving for V_0
The putty is dropped and thus V_0=0 you need to solve for V_f
which is the Velocity of the putty immediately before it hits the ground
You get the same number, but only by sheer luck.
Ok thank you...I think I am just going to wait and ask my teacher. =]
F\Deltat=\DeltaP
F\Deltat=mvf-mvi
\DeltaP=mvf-mvi
vo=13.8m/s
F=-27N
You've got part of it right.
The Average Force will be given by the change in momentum divided by the time interval. Since the final v is 0 then all you need to do is figure the momentum
V2 = 2*a*x = 2*(9.8)*(2.8 m)
wow that actually helped a lot! thank you!
The key to this problem was to break it up into two sub-problems.
By identifying correctly that you needed to use Impulse and Momentum, you knew that you needed to find the Velocity of the putty just before it hit the ground.
That Velocity could be found by using kinematics (the first sub-problem).
On a side note, whenever you see forces (or moments/torques) and time involved, chances are pretty good that you can use Impulse and Momentum equations.
Casey
I got it...and the computer said my answer is right, so I am good to go! Thanks to everyone who helped! =]
  • · Replies 22 ·
  • · Replies 23 ·
