What is the Best Approximation for Heat Transfer in Two-Dimensional Systems?
The discussion revolves around the application of the heat equation in two-dimensional systems, highlighting discrepancies between linear and presented solutions for heat transfer. The initial poster questions why the solutions differ despite both being based on conservation of energy and similar assumptions. A key point raised is that the problem may not be truly one-dimensional due to variations in cross-sectional area, which affects heat transfer rates. Participants emphasize the importance of correctly applying the heat equation to account for non-constant geometries and suggest that simpler one-dimensional models can sometimes misrepresent more complex scenarios. The conversation concludes with an acknowledgment of the need for accurate assumptions in modeling heat transfer.
c.teixeira
Hi there.
At first I tought of posting this thread on the homework category, but this is a conceptual doubt rather than anything else.
While revisiting Heat Transfer I stumbled upon a simple problem, that yet got me thinking.
It is as follows:
Before anything else, let me show you how they solve the problem:
Now, altough I understand and agree with their simple solution, I later tried to apply the heat equation to this problem:
\frac{\partial(κ\frac{\partial T}{\partial x})}{\partial x} + \frac{\partial(κ\frac{\partialτ}{\partial y})}{\partial y} + \frac{\partial(κ\frac{\partial T}{\partial z})}{\partial z} + \dot{q} = \rhoc_{p}\frac{\partial T}{\partial t}
Assuming constant properties, no internal heat generation, one-dimensional steady-state heat conduction:
\frac{\partial(κ\frac{\partial T}{\partial x})}{\partial x} = 0 \Leftrightarrow κ\frac{\partial^{2}T} {\partial x^{2}} = 0\Rightarrow T(x) = C_{1}x + C_{2} thus the temperature varies linearly with x.
Comparing this with the solution presented in the image, we see that they are different. Indeed, the solution may take values far apart from the linear solution, depending on the variation of A(x). Rest assured, if A = A(x), then certainly A_{x}\frac{\partial T}{\partial x} \neq Constant, as \frac{\partial T}{\partial x} = C_{1}.
But the most surprinsing is the following:
If we calculate the expression for the heat transfer rate using the linear solution:
q_{x} = -kA(x)\frac{\partial T}{\partial x} \Leftrightarrow q_{x} = -kA(x)C_{1}, and so the heat trasfer rate varies with x through A(x). And this violates the assumption that there is no sink and/or steady state condition.
Now, both the solution presented in the image, and the heat equation ( which I directly applied to this problem) are based on the conservation of energy, so clearly I am missing something. Why are this solutions so unlike if the laws, boundary bonditions and assumptions( namely steady-state, one-dimensional) are the same?
My guess is that this is explained in the following manner:
This two solutions are aproximations to a problem that is not 1 dimensional, but two dimensional. Therefore, they don't need to be equal.
What is your opinion or the matter? If my explanation is suitable, then what is the best approximation and why?
Thank you in advance,
c.teixeira
The heat equation that you present is for one-dimensional heat conduction with constant cross-sectional area. You have to derive the heat equation for the more general case of non-constant cross-sectional area:
First consider the energy contained in a small volume with area A and thickness \Delta x
E=e A \Delta x
The change of energy E in time for the volume is 'what comes in minus what comes out'. The 'heat flow' is following Fourier law: q = -kT_x
So the balance equation becomes:
(e(x,t) A(x)\Delta x)_t = q(x,t)A(x) - q(x+\Delta x,t)A(x+\Delta x)
Now divide by \Delta x and take the limit \Delta x \rightarrow 0
A(x)(e(x,t))_t = -(q(x,t)A(x))_x =-A(x)q_x(x,t) -q(x)A_x(x)
When e=\rho cp T then,
A(x)\rho cp T_t = (kT_xA(x))_x = A(x)kT_{xx} + kT_x A_x(x)
In the steady case you then have:
A(x)T_{xx} + T_x A_x(x) = 0
so you are missing a term. Integrating twice leads to
T(x) = C_2\int\frac{1}{A(x)}dx+ C_1
thank you for your answer bigfooted,
However, I have a hard time agreeing with that explanation.
Correct me if I am wrong (I meant it) but:
The heat equation I presented, re-posted above, is the most general form of the heat diffusion equation in Cartesian coordinates. It holds, regardless of the geometry of the problem. For example, one could apply the heat equation I presented to the study of heat on a sphere, altough that would be both laborious and unnecessary since spherical coordinates would be more suitable.
As to the rest of the derivation you presented, I agree with it. It seems right to me. But it is just the "formal" derivation of the solution "they" used to solve the problem. And that is indeed the issue. Why are this solutions so different, if they are both correct?
So, if I am right about my first paragraph, the question remains. More specificly:
c.teixeira said:
]My guess is that this is explained in the following manner:
Any opinions on the matter are welcome,
c.teixeira
q_{x}qx = -kA(x)\frac{\partial T}{\partial x}Tx \Leftrightarrow q_{x}qx = -kA(x)C_{1}C1, and so the heat trasfer rate varies with x through A(x). And this violates the assumption that there is no sink and/or steady state condition.
They stopped before evaluating the one-dimensional equation, saying that Ax( dT/dx ) must be constant, knowing that the area changes.
You evaluated the equation as simply one dimensional heat flow with no area change.
The problem is an execution of how flows other than one dimensional, can be analyzed and solved by using the simpler one dimensional Fourier law, with correct assumptions, rather than using the all inclusive three dimensional equation.
Ok, I undestood your explanation. It makes sense. It is much like the explanation I tough to myself.
Thank you,
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
