What is the capacitance of a capacitor constructed using foil and paper?
  • Thread starter Thread starter Number1Ballar
    Capacitor
The discussion centers on calculating the capacitance of a capacitor made from two sheets of foil and a paper dielectric. The area of the sheets is determined to be 0.0125 m², and the thickness of the paper is 0.0003 m. The dielectric constant (k) of the paper is confirmed to be 3.7, which is essential for the calculation. The final capacitance is calculated using the formula C = (k * ε₀ * A) / d, resulting in a capacitance of 1.36 nF. Understanding the roles of ε₀, ε, and k is crucial for accurate calculations in capacitor design.
Number1Ballar
Suppose you constructed a capacitor using two 5cm*25cm sheets of foil and a 0.3mm thick piece of paper (k=3.7). What is its capacitance? Calculate to 1 decimal place. Use units of "nF". (1nF=1*10^-9F)
where d is the distance between the 2 sheets, A is the area of 1 sheet.
The equation above is the only equation I could find that involved area of a capacitor. I found A = (0.25m)(0.05m) = 0.0125m2. I don't know where the paper comes in, nor do I understand what 'k' is and what formula I am supposed to use for it.
I'm not sure but I think k is the dielectric constant of paper.
See, the way a capacitor works is that you have two plates next to each other, charged oppositely. This creates an electric field between them, making the electrons want to jump across to the positive side.
In order to get more out of these plates, you put something in between, which lowers the electric field in between the plates. This means that you now have to pile up more charge on the plates to have the same kind of electric field as you had before, giving your capacitor more storage space, i.e. capacitance.
So in this case you are putting paper in between the two plates, and I *believe* that that is what "k" is and you just plug that in for epsilon.
If you want to use that equation (and I would suggest that) then you need to figure out what your values of \epsilon and \it{d} are.
It would help to picture this capacitor that you're trying to build. From wikipedia:
The simplest practical capacitor consists of two wide, flat, parallel plates separated by a thin dielectric layer.
You need to investigate what a dielectric is and how that relates \epsilon and \it{k}. I'll give you a hint and tell you that \epsilon_{0} is known as the permittivity of free space.
Hope this helps.
hmmm okay I'm starting to see how a capacitor works, but am still a little confused on how to do this problem.
I see that if the paper was in between these 2 sheets, then 'd' would equal 0.0003m, 'A' would equal 0.0125m2, and for \epsilon I would plug in the value of k given?
so..
C = (3.7)(0.0125m2) / (0.0003m) = 154.17 ...which seems quite high for the answer...I think I'm still not getting something
You need to better understand the differences between \epsilon, \epsilon_{0} and \it{k}. Try http://en.wikipedia.org/wiki/Dielectric_constant" where \epsilon_{s} as given in their equation is what your equation calls \epsilon.
actually I think I figured it out..
C = (3.7)(8.85 X 10-12 F/m)(0.0125m2) / (0.0003m) = 1.36 X 10-9F
= 1.36 nF
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
