What is the Collatz Problem and how can it be solved?
  • Level: Undergrad
  • Thread starter Thread starter Organic
410 replies · 42K views · last reply
Right, you say we must be open to your ideas, but you won't listen to us.
Definitions must not contradict what we know, yet in your newdiagonalpdf you define an array using some (undefined) construction that I've shown doesn't have the properties you define it to have.
Listen to your own advice.
So, where does Hurkyl's measure theoretic proof go wrong for showing there is no bijection from N to R? And don't start this invariant self similarity crap again because that isn't what the proof is using. We can dress it up some more if you don't understand measure theory, and use Baire's Category theorem - a one point set is nowhere dense, hence the countable union of them is nowhere dense and thus cannot be R.
The thing is, sets do not have any structural quantities.
The only thing that matters about a set is the elements it contains.
And up to bijection1, the only property of a set is its cardinality2.
So, basically, when you're using set theory to describe things, at the ground floor, quantity is the only thing that matters3. Once you have a set, you then impose structure on that set. For instance, you can impose an order on a set, and the result is called an ordered set So, for example:
(R, <) is an ordered set4
(where R stands for the set of real numbers, and < stands for the usual ordering on them)
Now, if we're being entirely proper, we should say "(R, <) is an ordered set" or "< is an ordering for R", not "R is an ordered set" or "R is an ordered set with ordering <" The reason is that the structure of order is something that is beyond the meaning of the term 'set'. That being said, mathematicians often abbreviate themselves by using "R" when they should be using "(R, <)" for economy of notation.
Another structure we can impose on a set is that of being a field. For example
(R, +, *) is a field4.
(Where R stands for the set of real numbers, and + and * stand for the usual addition and multiplication operation on them)
Again, a mathematician will often abbreviate himself by saying "The field R" instead of saying "The field (R, +, *)". Anyways, the important thing is that the structure of + and * are not part of the set of real numbers; they are additional structure imposed beyond that of being a set.
For one more example, there is the ordered field (R, +, *, <). This is yet another structure that is different from the previous ones. The ordered set (R, <) does not have arithmetic, and the field (R, +, *) is not ordered.
To say it again, the point I'm making is that sets do not have structure! All sets have are elements! If you are using a structure on some set, that is something that is beyond its definition as a set!
To state my point in a different way, if you don't the notion of "quantity" and "elements" to be there from the very beginning, you can't use a set theoretic description of your ideas.
Hurkyl
1: In laymen terms, this means that if we consider two sets to "the same" if there is a bijection between them.
2: and any property that can be derived knowing nothing about the set but its cardinality, such as the property of being finite (cardinality equal to a natural number) or infinite (cardinality not equal to a natural number)
3: More precisely, it is cardinality that matters.
4: I am being somewhat narrow here for clarity. This is the set theoretic way to write a field; the theory of fields does not have things like ordered triples or sets of elements! Also, even when using ZF, there exist fields for which a set of all elements does not exist, such as the surreal numbers. Also, instead of what I wrote, one would often write (R, +, *, 0, 1), putting the additive and multiplicative identities into the notation.
My point of view disagree with Contor's point of view about a collection with cardinality aleph-1 of infinitely many objects (={...} form) that can construct a solid line (={___} form)
The idea that lines have points on them goes back at least to Euclid; I imagine much further. :smile:
I imagine the concept that lines are made out of points is just as old, but modern mathematics doesn't require this point of view. In fact, depending on the circumstance, mathematicians can be downright pedantic about insisting that you keep the ideas of "a line" and "the points on a line" separate.
Definitions are only tools of meaning, if they contradict the meaning then we have to find another definitions that can express the meaning.
In this case "countable" and the "must have" connection with N is a conceptual mistake.
Shortly speaking:
"A set S is countable if and only if there exists a function from the natural numbers onto S."
Is a conceptual mistake.
Mathematics need a phrase that means "There is a function from N onto S". The word countable was chosen. Thus, when a mathematician means "there is a function from N onto S", we use the phrase "S is countable", and when a mathematician uses the phrase "S is countable", we mean "there is a function from N onto S".
Mathematicians are using the definition of the phrase "S is countable" as a tool to express the meaning "There is a function from N onto S".
So, I'm not sure what your objection is. Do you just not like the word mathematicians have chosen for this purpose? If we used the term "S is gazorninplat" to mean "there is a function from N onto S", would it be acceptable to you? If so, then R is not gazorninlpat, and anytime you see a mathematician use the word "countable" you should mentally substitute the word "gazorninplat", and be happy!
R is not countable. Please prove it is. None of the things you've claimed so far is a proof.
You say complementary multiplication is not commutative. I would question the assertion that it is a multiplcation. Not because it is not commutative, but because it is not a binary operation from NxN to N. It is an operation on certain combinatorial structures. I might call them trees but you don't believe in the usual definition of tree. For instance, you calculate 2*3. What is the outcome? Which number is it? Moreover, as you've challenged us to produce complementary additive and multiplicative operations (on N) would you mind stating what complementary means in this sense, and why we must define it on N when you don't define it on N.
And if you dismiss Hurkyl's use of the word structure as unimportant, how come you use the same word in your quote from one of your writings?
You don't like N in countable? Why not? the idea of bijection with N and the reason you have the word 'count' in there is because then you can label the elements with the counting numbers.
If you don't like that then we can say a set is countable if it is bijection with:
1. Q
2. Z
3. The set of primes
4. The set of even integers
5. The set of polynomials with coefficients in F_2.
6. The set of spheres in R^3 whose centres lie at rational coordinates and whose radius is an integer.
7. The set of all finite groups. (Up to isomorphism. Or the set of all finite sets up to isomorphism in the category SET)
Anyway, here's another question you've still not answered.
Why does the fact that the arrays with columns labellled 1 to n and rows labelled 1 to 2^n forms a complete description of the power set of 1,..,n imply that the case for an infinite countable set also has a countable number of rows? You keep saying 'by construction'. What construction? I don't see one in your latest version. You had one once, and using that we've proved again and again that you've made a mistake. Now you don't even attempt to describe the construction. Why not? What is it?
Hurkyl,
There is no such a thing structuarl quantitiy, and I never wrote such a thing.
I wrote structoral property, and a set has structural property, please take for example the Von Neumann Hierarchy:
Code:
[b][i]0[/i][/b] = |{ }| (notation = {})
[b][i]1[/i][/b] = |{[b]{[/b] [b]}[/b]}| (notation = {0})
[b][i]2[/i][/b] = |{[b]{[/b] [b]}[/b],[b]{[/b]{ }[b]}[/b]}| (notation = {0,1})
[b][i]3[/i][/b] = |{[b]{[/b] [b]}[/b],[b]{[/b]{ }[b]}[/b],[b]{[/b]{ },{{ }}[b]}[/b]}| (notation = {0,1,2})
[b][i]4[/i][/b] = |{[b]{[/b] [b]}[/b],[b]{[/b]{ }[b]}[/b],[b]{[/b]{ },{{ }}[b]}[/b],[b]{[/b]{ },{{ }},{{ },{{ }}}[b]}[/b]}| (notation = {0,1,2,3})
and so on.
A set is only a framework to explore our ideas.
The concept of oreder set does not depend on the quantity concept as can clearly shown here:
Code:
[b]
By Complementary Logic multiplication is noncommutative,
but another interesting result is the fact that multiplication
and addition are complementary opreations that can be ordered
by different symmetry degrees where quantity remains unchanged
for example:
A Number is anything that exists in ({},{__})
Or in more formal definition:
({},{_}):={x|{} <-- x(={.}) AND x(={._.})--> {_}}
Where -->(or <--) is ASPIRATING(= approaching, but cannot become closer to).
If x=4 then number 4 example is:
Number 4 is a fading transition between multiplication 1*4 and
addition ((((+1)+1)+1)+1) ,and vice versa.
This fading can be represented as:
(1*4)              ={1,1,1,1} <------------- Maximum symmetry-degree,
((1*2)+1*2)        ={{1,1},1,1}              Minimum information's
(((+1)+1)+1*2)     ={{{1},1},1,1}            clarity-degree
((1*2)+(1*2))      ={{1,1},{1,1}}            (no uniqueness)
(((+1)+1)+(1*2))   ={{{1},1},{1,1}}
(((+1)+1)+((+1)+1))={{{1},1},{{1},1}}
((1*3)+1)          ={{1,1,1},1}
(((1*2)+1)+1)      ={{{1,1},1},1}
((((+1)+1)+1)+1)   ={{{{1},1},1},1} <------ Minimum symmetry-degree,
                                            Maximum information's
                                            clarity-degree
                                            (uniqueness)
                Uncertainty
  <-Redundancy->^
    3  3  3  3  |          3  3             3  3
    2  2  2  2  |          2  2             2  2
    1  1  1  1  |    1  1  1  1             1  1       1  1  1  1
   {0, 0, 0, 0} V   {0, 0, 0, 0}     {0, 1, 0, 0}     {0, 0, 0, 0}
    |  |  |  |       |__|_ |  |       |__|  |  |       |__|_ |__|_
    |__|__|__|_      |_____|__|_      |_____|__|_      |_____|____
    (1*4)            ((1*2)+1*2)      (((+1)+1)+1*2)   ((1*2)+(1*2))
 4 =                                  2  2  2
          1  1                        1  1  1          1  1
   {0, 1, 0, 0}     {0, 1, 0, 1}     {0, 0, 0, 3}     {0, 0, 2, 3}
    |__|  |__|_      |__|  |__|       |  |  |  |       |__|_ |  |
    |     |          |     |          |__|__|_ |       |_____|  |
    |_____|____      |_____|____      |________|       |________|
(((+1)+1)+(1*2)) (((+1)+1)+((+1)+1))  ((1*3)+1)        (((1*2)+1)+1)
   {0, 1, 2, 3}
    |__|  |  |
    |     |  | <--(Standard Math language uses only this [i]no-redundancy_no-uncertainty_symmetry[/i])
    |_____|  |
    |________|
    ((((+1)+1)+1)+1)
Multiplication can be operated only among objects with structural identity,
where addition can be operated among identical and non-identical
(by structure) objects.
Also multiplication is noncommutative, for example:
2*3 = ( (1,1),(1,1),(1,1) ) , ( ((1),1),((1),1),((1),1) )
3*2 = ( (1,1,1),(1,1,1) ) , ( ((1,1),1),((1,1),1) ) , ( (((1),1),1),(((1),1),1) )
[/b]
If there is a function from N to S, then there certainly must be a function from N to S...
I don't see what the problem is. Anyways, I'll give a better response later!
The huge great problem that you have never overcome is that you at no point prove that the rows you enumerate are in bijection with the power set of N.
So.
1. Write down here in this forum the construction you use to generate the r'th row of the array for the ones labelled 1,2,3,, no need to do it for the 1',2' etc2. Explain where the proof that this enumerates only the finite and cofinite sets is wrong. I've posted it at least 4 times in this thread and you've not said what's wrong with it beyond asserting that the rows mus by construction be the power set, yet you've not defined the construction.
3. Here we go again, let's od it one step at a time.
Just take the diagram as in Newdiognal.
the first column is the alternating sequence 0101010101...
the second goes 001100110011...
the rth goes in alternating blocks of r 0s and r 1s.Is that correct? and all the rows so produced are in correspondence with the power set of N, aren't they?
Just answer this for now
Take the array as written in Newdiagonal.
is it true that the construction you allude to is to write the right hand column as 01010101... alternating 0s and 1s, the next column is 00110011.. alternating pairs of 0s and 1s, and that the rth row is r 0s then r 1s then r 0s and so on?
We can ignore the rows yo've now added in as they only correspond to the countable set of cofinite subsets.
Hurkyl,
My problem is not the word "countable" but the "must have" connection between this word and N.
R is also countable and it is defenetly not N because |R|>|N|.
The proof that R is countable can be found here:
http://www.geocities.com/complementarytheory/NewDiagonalView.pdf
If your problem is that I use the notations of N to mark each unique 01 row sequence,
then you can use notations tricks, for example:
By using this trick 0 0' 1 1' 2 2' 3 3' 4 4' ( please see http://home.ican.net/~arandall/abelard/math12/Cantor.html )
we can build this list:
Code:
    3 2 1 0
   2 2 2 2
   v v v v
...1 1 1 1 <--> 1
...1 1 1 0 <--> 1'
...1 1 0 1 <--> 2
...1 1 0 0 <--> 2'
...1 0 1 1 <--> 3
...1 0 1 0 <--> 3'
0 0' 1 1' 2 2' 3 3' 4 4'... is good for base 2.
For base 3 the trick is: 0 0' 0'' 1 1' 1'' 2 2' 2'' 1'' 3 3' 3'' 4 4' 4''...
For base 4 the trick is: 0 0' 0'' 0''' 1 1' 1'' 1''' 2 2' 1'' 3 3' 3'' 3''' 4 4' 4'' 4'''...
And so on ...
Shortly speaking cardinality is first of all based on unique structural differences between elements that have to be notated by equivalence structural periodic repetitions of notations that related to these structural differences.
It means that from structural point of view this mapping
Code:
(structural periodic notations = 1)
1 <--> 1
2 <--> 2
4 <--> 3
3 <--> 4
5 <--> 5
8 <--> 6
7 <--> 7
6 <--> 8
can be done, where this mapping
Code:
(structural periodic notations = 1 <--> structural periodic notations = 2)
1 <--> 1
2 <--> 1'
3 <--> 2
4 <--> 2'
5 <--> 3
6 <--> 3'
7 <--> 4
8 <--> 4'
cannot be done.
Shortly speaking, structural property is reacher and much more interesting then quantity property.
I'll say it again, mapping between elements must be checked first of all by the structural propery that exists (or does not exist) between these elements.
By structual point of view aleph0 < 2^aleph0 < 3^aleph0 ... < n^aleph0 < (n+1)^aleph0
By quantitative point of view aleph0 < 2^aleph0 = 3^aleph0 ... = n^aleph0 = (n+1)^aleph0
Is there any reason why you will not give a direct answer to a direct question?
Is that construction above that I sepcified the construction you are using in Newdiagonal.pdf?
The problem is that each row you've marked with an integer, depending on the version you're now using, contains either finitely many 1s or finitely many zeroes and is therefore not in bijection with the power set.
You've not offered to explain the construction. Until such time as you explain the construction you have nothing concrete to work with. Note you cannot deduce anything by induction on the finite case; that is not how induction works.Note I wish to amend my observation of the construction to state the rth column has alternating blocks of 2^r 0s and 1s. This doesn't affect the deductions about the construction since 2^r>r
It was a typo. I meant to say "structural property".
What about it?
No, cardinality is based on the idea of "set" and "invertible function", nothing else. (though it is a generalization of the idea of "quantity" which, again, is not a structural idea)
I don't see any ordering given in your example. Anyways, an ordered set is defined to have a set and an order. We can talk about "quantity" in relation to sets, so we can talk about "quantity" in relation to ordered sets.
Shortly seaking, structural property is reacher and much more interesting then quantity property.
Yes, structural properties are generally richer than the "quantity property". However, the point still stands that no matter how much structure you pile upon a set, it is still a set, and thus we can still talk about the "quantity property" of the set.
Acutally I think you'll find that r^(aleph-0)=s^(alpeh-0) for all r and s in N.
Originally posted by Organic
Matt,
How my 01 matrix can be finite if there are infinitely many columns and infinitely mant rows?
Where on Earth do you think I state the number of rows and columns is finite? I said that any row has either a finite number of 1s in it or a finite number of 0s. That does not say that a row is finite in length
Matt,
How my 01 matrix can be finite if there are infinitely many columns and infinitely many rows where it's width's magnitude=aleph0 and it's length's magnitude=2^aleph0?
There is no structural point of view! Cardinalities ignore ALL "structure"!
The only point of view where 2^aleph0 < 3^aleph0 is one where you've actually changed the definition of the symbols!
Matt,
Erm, no sorry, at no point have I specified that the matrix is finite. I've told you how to make the matrix up using finite blocks repeated an infinite number of times.
In fact I'm the only one who's specified how to construct it. Why don't you correct that, and tell me what the entries in the r'th row are, and how they are organized.
Matt,
Do you agree that the length of my matrix has a magnitude of 2^aleph0 where its width has the magnitude of aleph0?
You make a big conceptual mistake is you think thet there
must be infinitely many 0 AND 1 notations in each row, because in this case no one of these rows has its unique data.
It means that each row can be reduced to ...1010101010 or ...0101010101 data.
It has aleph0 rows, because it is a list.
must be infinitely many 0 AND 1 notations in each row, because in this case no one of these rows has its unique data and can be reduced to infinitely many rows of ...1010101010... data.
So ...011011011 never appears in your list?
What about ...100001000100101?
Your last post makes little sense - you state that it is possible for the rows to correspond to the power set of N and for there to be no row corresponding to the even integers.
By implication the sets of rows and columns both have cardinality aleph-0, since you enumerate them.
You also claim that the rows are in correspondence with the power set of N, and thus the rows of the matrix must be a set of cardinality 2^alpeh-0.
My contention is that if you enumerate the rows as you do, whereby for row n you take the decomposition of n-1 in binary expansion and write the coeffs going from right to left, that the rows you enumerate do not form a set that is in correspondence with the power set - rather obviously they are exactly in correspondence with the finite subsets. You then try to muddy the waters by including the cofinite sets, without noticing that you are thus contradicting your earlier held beliefs.I do not state that every row must have infinitely many 0s and 1s. But that there must be some rows (uncountably many as it happens) that do contain infinitely many 0s AND 1s, if this is to be all of the power set. There is none in the enumerated part of your 'matrix'Now, are you going to explain the construction of the 'matrix', so far you've not offered any way of constrcuting it.
Hurkyl,
Please this time pay attention to the word "each".
It means that in ths case (which is not my case, where both forms exist) each row can be reduced to ...1010101010 or ...0101010101 data.
Matt,
Both cases must exist in my 01 matrix.
Simply there is no other way.
Hurkyl,
No one is saying (apart from you here) that there must be infinitely many 0s and infinitely many 1s in every row, indeed you don't produce a single row where that is true.
what on Earth does it mean to 'reduce' a row to ..0101010 or ..1010101?
no one of these rows has its unique data? eh? That looks like a meaningless sentence.
"each" might be the only word in that sentence that makes sense! (Ok I'm exaggerating, but only slightly)
Does ...011011011 appear in your list?
Does ...100001000100101 appear in your list?
Does ...01010101 appear in your list?
Do you consider these three sequences different?
Matt,
Why *must* there be all of the strings with infinitely many 1s and infinitely many 0s in them? Why? Give me one reason. If you are about to say 'by cosntruction' which construction, you've not offered one? SO which construction - just tell me the r'th entry in the t'th column, that's all, even if it's by some inexplicit way like my comment that it appears to be
the r'th column is the sequence of alternating blocks of 2^r 0s then 2^r 1s, you may then read off the rows.
It's a simple request. Note you cannot say by the axiom of infinity induction on the power value' because that is not acceptable; oh you're about to cry foul and say I'm restricting you, but as you've never explained what the axiom of infinity of induction is you can't use it. Induction tells us something is true for an infinite number of cases, it does not tell us what, if anything, is true for an infinite set in the index if that even makes sense. For instance one can easily define the n'th fibonacci number and get an explicit value for it by induction. what would it mean to even talk of the aleph-0'th fibonacci number?
Matt,
In this private case of 01 matrix we can distinguish between to cases of uniquness.
Case 1: there are infinitely many 0 AND 1 notations in each row with a unique order of 01 combinations.
Csae 2: there are finitely many 0 XOR 1 notations in each row with a unique order of 01 combinations.
Only case 1 can be reduced to ..0101010 or ..1010101 where by reduced I mean that we don't care about the order of 01 combinations.
Matt,
Csae 2: there are finitely many 0 OR 1 notations in each row with a unique order of 01 combinations.
Firstly, ..010101 is not even on the list, secondly why can't you reduce both those to the same thing, thirdly, rubbish, of course you can't do that as then you don't have a bijection (do you even know what a bijection is?), and fouthly why aren't you answering the calls to write down the construction of the enumeration of the matrices rows? It shouldn't be very hard. Fifthly stop saying private when you mean particular, they are not synonyms.
Matt,
If the word induction is wrong here then we can use the word iteration instead.
Matt,
Why would that help? If you've made this construction surely you know how you made it? How come you get to be so sure of yourself and that Hurkyl and I are wrong and don't understand when you don't even know the meaning of the terms you use?
Matt,
..010101 is not even on the list, secondly why can't you reduce both those to the same thing, thirdly, rubbish, of course you can't do that as then you ..
Because I have the right side of my matrix then case 1 can be reduced to ...0101010 or ...1010101
Matt,
right side of the matrix? what? What's case 1. why won't you answer the relevant questions and produce the alleged construction of the enumerated list. stop obfuscating and produce the proof of the result that *must* state why the enumerated list is in bijection with the power set, and why you are allowed to identify different elements of the power set when you are looking for a bijection!
Are you implying that the alternating sequence ...010101010 is on the right hand of the two lists you're now using? despite the fact that every row in the right hand list is eventually one 'by construction' that is the cofinite list. of course for a while you were insisting that it was on the left list too cos that was a complete enumeration of the power set as well.
