What is the Constant λ in the Wave Equation for Normalising the Wavefunction?
4 replies · 2K views
ParoxysmX
Determine the constant λ in the wave equation
[itex]\Psi(x) = C(2a^2 x^2 + \lambda)e^{-(a^2 x^2/2)}[/itex]
where [itex]a=\sqrt{mω/\hbar}[/itex]
Some standard integrals I guess
So I believe the wave equation just needs to be normalised. Using the usual conditions for normalisation,
[itex](C2a^2 + C\lambda)^2 \int^{∞}_{-∞} | x^2 e^{-(a^2 x^2/2)} + e^{-(a^2 x^2/2)} |^2 dx =1[/itex]
From there,
[itex](C2a^2 + C\lambda)^2 \int^{∞}_{-∞} |2x^2 e^{-(a^2 x^2/2)}|^2 dx =1[/itex]
Then squaring the function inside the integral and moving the '4' outside the integral as it is a constant,
[itex]4(C2a^2 + C\lambda)^2 \int^{∞}_{-∞} x^4 e^{-(a^2 x^2)} dx =1[/itex]
Now that should be a standard integral but I don't know any involving an x term to the fourth power. Or perhaps I've done something else wrong?
Since when is
[(ab+c) d]^2 = (a+c)^2(bd+d)^2
The next step is also completely wrong. Start again from ##|\psi|^2 = \psi^* \psi##. You should also allow ##C## and ##\lambda## to be complex.
If the function doesn't contain any complex exponentials, then [itex]\psi^{*}[/itex] is the same as [itex]\psi[/itex], isn't it?
As all physical observables depend ultimately on ##| \psi |^2##, the wave function of a physical system is only defined up to a complex phase. In other words, ##\psi## and ##\psi e^{i \delta}##, with ##\delta## real, decribe the same thing. Therefore, you can choose the normalization constant ##C## in
\psi(x) = C f(x)
to be real, because if it is complex, you can always do a rotation in the complex plane such that ##C' = C e^{i \delta}## is real.
But you also have the ##\lambda## in there and, unless told otherwise, you can't assume that it is real. You should appraoch the problem without restricting ##C## or ##\lambda## to be real, and see what you get.
use Maple to do the follow step:
assume(a>0)
int(C*(2*a^2*x^2+B)*exp(-(a^2*x^2)/2),x=-infinity..infinity)
where B is your λ. then we can get the result is
(B+2)*C*(2*Pi)^0.5/a
I hope this can help you
