What Is the Correct Speed of the Moon at Perigee?
  • Context: Undergrad
  • Thread starter Thread starter ryanie
    Moon Speed
The discussion revolves around calculating the speed of the Moon at perigee using gravitational formulas. Participants explore the correct application of the formula, the appropriate values for constants, and the implications of including the Moon's mass in the calculations. The scope includes mathematical reasoning and technical clarification.
  • One participant presents a formula for calculating the Moon's speed at perigee but expresses uncertainty about their result.
  • Another participant points out the need to show units to identify potential errors in the calculations.
  • A subsequent response indicates that the initial result is significantly incorrect, suggesting unit inconsistency as a possible issue.
  • A participant updates their values for gravitational constant, mass of the Earth, and distances, yielding a new speed result, but questions its correctness.
  • Another participant acknowledges the new result is closer but still incorrect, noting the Moon's mass should be considered in the calculations.
  • A participant questions whether they are using the wrong formula since it only accounts for the Earth's mass.
  • One response confirms that the formula used is incorrect without providing an alternative.
  • A participant proposes a new speed value that is significantly higher than previous estimates, prompting skepticism about its reasonableness.
  • Another participant suggests that a rough estimate based on known orbital parameters would yield a speed around 1000 meters per second, indicating that at least two of the proposed answers are unreasonable.
Participants do not reach a consensus on the correct speed of the Moon at perigee, with multiple competing views and calculations presented throughout the discussion.
There are limitations regarding the assumptions made about the mass of the Moon and the applicability of the formula used. The discussion also highlights the importance of consistent units in calculations.
ryanie
Hi
Im trying to calculate the speed of the moon at perigee but i don't know where I am going wrong.
As i know the formula is v = sqrt[ GM( (2/p) - (1/a) ) ]
where
g = gravitation constant
m = mass of the earth
p = distance perigee from the earth
a = semi major axis
The values I am using are
g= 6.67384e-11
m = 5.97219e+24kg
p = 363295km
a = 384399km
the result I am getting is 75.5524m/s
Im not even sure if this is correct, could someone advice me in the correct method
*EDIT, showed the unit I am working in. Also as a side note i pulled the data of wikipedia*
Show your units. There is at least one error in this regard that would be more easily visible if you did.
What units are you using?
That's not even close.
You did not show all of the units you are working in. G has units, too, and this is the source of your problem. You are using inconsistent units.
ok so
the new values I am using
G = 6.67384 × 10^-11 m3 kg-1
m = 5.97219*10^24 kg
p = 363295000 m
a = 384399000 m
im getting a result of 1075.7984 m/s
wrong? correct?
That's much closer, but it's still wrong. That result would be correct if the Moon's mass was much, much less than the mass of the Earth. It isn't. The mass of the Moon is about 0.0123 times the mass of the Earth. That's small but it is not negligible.
BTW, please stop using text speech. It's "I', not "i", "I'm", not "im".
The formula I'm using does not take into account the mass of the moon, only the mass of the earth. Am I using the wrong formula?
Yes.
What is the correct formula?
is the correct answer 1076040.527 m/s ?
You have proposed three answers now, varying from 75 meters per second to over one million meters per second. A tiny bit of sanity checking would show you that at least two of those answers are unreasonable.
You know that the radius of the moon's orbit is roughly 360,000 km.
You should know that the period of the moon's orbit is roughly 28 days.
That is enough for a back-of-the-envelope estimate of 360,000,000*2*pi meters in 28*24*60*60 seconds. That's roughly 1000 meters per second.
DH has given you a big hint by saying of your second answer, the one close to 1000 meters per second: "that answer would be correct..."
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 18 ·
