What is the current in Resistor2?
  • Thread starter Thread starter DuckAmuck
    Current
The discussion centers on calculating the current through resistor R2 when a switch is closed in a circuit. Participants clarify that while some believe the current through R2 would be zero due to a short circuit, this is incorrect. Instead, the current through R2 is a fraction of what it would be if R2 were in series with R1. The equivalent resistance of R2 and the wire is calculated using the formula Rp = (1/R2 + 1/W)^(-1), where W represents the wire's resistance. Practical considerations, such as the wire's resistance and the internal reactance of the cell, affect the current flow.
  • Understanding of Kirchhoff's laws
  • Basic knowledge of electrical circuits
  • Familiarity with parallel and series resistor calculations
  • Concept of equivalent resistance
  • Study the calculation of equivalent resistance in parallel circuits
  • Learn about the effects of internal resistance in batteries
  • Explore transient analysis in electrical circuits
  • Investigate the impact of temperature on wire resistance
Electrical engineering students, hobbyists working on circuit design, and professionals involved in circuit analysis and troubleshooting.
DuckAmuck
Diagram1: http://i.imgur.com/StJae.png
Diagram2: Close the switch http://i.imgur.com/PnSIH.png
What is the current in resistor2? Please show the math. Thank you. [No, it's not a homework problem, I'm just curious.]
Some people say it would short out on resistor 2 and current would be zero, but that's supposedly not right. The current becomes some fraction of what it would be if R2 were in series with R1.
I am aware of Kirchoff's laws, but this is still stumping me. Thanks in advance.
What do you say?
What fraction?
Once the switch is closed, is there a difference between your two diagrams?
No, no difference.
DuckAmuck said:
No, no difference.
OK, so what's the equivalent resistance of R2 and the bare wire, which are in parallel?
When current flows through that combination, what percentage would go through the wire?
That's exactly what I don't know.
Well, start there. What's the equivalent resistance of two resistors in parallel?
where W is the resistance of the wire.
Good. So what will you put as the resistance of the wire?
The problem here is between the abstract theoretical perfect components in a circuit diagram, and the reality of a practical component. Your piece of wire across R2 and your closed switch both have a theoretical resistance of zero ohms. Of course, in practice there would be some small resistance in both. If you want the 'real' and accurate figure for the current you will need to know these values. You may also find that the values change with time as the current heats the wire and the switch. You would need details of this dynamic too for a realistic calculation. Further more, the cell has an internal reactance, and the whoe circuit has inductance and capacitance. This will play a part during the transient when the switch is closed. But we are talking about very small quantities here - to all intents and purposes the switch shorts out R2 and the current through R2 is zero.
I highly doubt that that is the issue here.
Ha ha - I think you might be right. I stand corrected.
