What is the depth x of the oil?
  • Thread starter Thread starter looi76
    Depth Oil
The discussion focuses on calculating the depth of oil (x) in a borehole that is 2000 meters deep, containing both oil and water. The pressure at the bottom of the borehole is 17.5 MPa, with oil density at 830 kg/m³ and water density at 1000 kg/m³. The initial calculation incorrectly considers only the water's contribution to pressure. The correct approach involves accounting for both oil and water, leading to the equation: 17.5 × 10^6 = 830 × g × x + 1000 × g × (2000 - x).
  • Understanding of fluid statics and hydrostatic pressure principles
  • Knowledge of density and its role in pressure calculations
  • Familiarity with the equation Pressure = Height × Density × Gravity
  • Basic algebra for solving equations
  • Review hydrostatic pressure calculations in multi-fluid systems
  • Study the impact of fluid density on pressure in boreholes
  • Learn about the applications of Pascal's principle in fluid mechanics
  • Explore advanced topics in fluid dynamics related to oil extraction
Students in engineering or physics, professionals in petroleum engineering, and anyone involved in fluid mechanics or hydrostatics will benefit from this discussion.
looi76
The bore hole of depth 2000m contains both oil and water as shown. The pressure at the bottom is 17.5MPa. The density of the oil is 830kgm^-3 and the density of the water is 1000kgm^-3.
http://img384.imageshack.us/img384/6944/10062008fj0.png
Pressure = Height x Density x Gravity
17.5 \times 10^6 = x \times 1000 \times 9.81
x = \frac{17.5 \times 10^6}{1000 \times 9.81}
x = 1789.893986m
Where did I go wrong?
Both oil and water have a contribution in the pressure:
p = \rho g \Delta h
So we get:
17.5 \cdot 10^6 = 830 \cdot g \cdot x + 1000 \cdot g \cdot(2000-x)
  • · Replies 21 ·
21K
  • · Replies 29 ·
