What is the derivation of Maxwell's 4th equation for a static electric field?
The discussion centers on the derivation of Maxwell's 4th equation for a static electric field, specifically relating to the curl of the magnetic field B. The curl of B is established as equal to the magnetic permeability (μ₀) times the current density (J), evaluated at a point outside the circuit (R₂). It is confirmed that the curl of B is zero everywhere except along the circuit itself, where the current flows. This derivation aligns with principles taught in Electromagnetism courses and utilizes the Biot-Savart law for calculations.
  • Understanding of Maxwell's equations
  • Familiarity with the Biot-Savart law
  • Knowledge of magnetic permeability (μ₀)
  • Concept of curl in vector calculus
  • Study the application of the Biot-Savart law in electromagnetic theory
  • Explore the mathematical derivation of Maxwell's equations
  • Learn about the implications of curl in electromagnetic fields
  • Investigate the relationship between current density and magnetic fields in circuits
Physics students, electrical engineers, and anyone studying electromagnetic theory will benefit from this discussion, particularly those focusing on the derivation and implications of Maxwell's equations.
Master J
In my derivation of Maxwell's 4th equation from the empirical Biot Savart law, for a static electric field, I have that the curl of B is equal to the magnetic permeability times the current density.
Now, the source coordinates (i. the circuit) are given by R_1 ( R is a vector). The field coordinates, that is, a point outside the circuit at which the field is measured, are given by R_2. As stated above, the curl of B is equal to the magnetic permeability times the current density, but this current density is evaluated at R_2.
This is of course zero. So this means that the curl of B is zero everywhere except on the circuit itself (in the wires). Am I correct? The derivation is the one I was thought in my Electromagnetism class, so I don't doubt it is correct.
Could someone perhaps expand on this for me. Am I correct?
You meant magnetic field?
the current density is at the source:
\nabla \vec B = \mu_0 \vec J \hbox { better yet using integral form } \int_C \vec B \cdot d\vec S = \mu_0 I
Means the magnetic field is generated by the current I passing through a wire etc. The magnetic field is circulating around the current carrying wire. so even if you have a field point destinated by \vec R_2, all you do is to put into this formula
d\vec B_{(R_2)} \;=\; \frac {\mu_0 I}{4\pi}\;\; \frac {d\vec l X \vec R_2 }{R_2^3}
For any point ( as you called R_1) and the magnetic field from the complete wire is
\vec B_{(R_2)} \;=\; \frac {\mu_0 I}{4\pi}\;\; \int _C \frac {d\vec l X \vec R_2 }{R_2^3}
I don't use R_1 because the wire that carry current is always the source, you cannot take the magnetic field at R_1 and find the magnetic field in R_2.
  • · Replies 0 ·
  • · Replies 54 ·
