What is the derivative of x^x and how to sketch sin(x)/x by hand?
  • Thread starter Thread starter ponjavic
    Derivative
The discussion revolves around the derivative of the function x^x and the sketching of the function sin(x)/x. Participants explore the methods for finding the derivative of x^x and the implications of different approaches. Additionally, they discuss the characteristics of the sin(x)/x function, particularly its behavior near zero and its oscillatory nature.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants examine various methods for differentiating x^x, questioning the validity of certain steps and exploring the implications of the chain rule. They also discuss how to sketch sin(x)/x, considering its limits and zero crossings, and the effect of the decreasing amplitude on the wave shape.
The conversation is active, with participants providing insights and corrections regarding the derivative of x^x. There is ongoing exploration of how to accurately sketch sin(x)/x, with some participants suggesting the use of bounding lines and discussing the function's evenness. Multiple interpretations of the behavior of sin(x)/x are being explored without a clear consensus.
Participants note the complexity of integrating x^x and the challenges in determining the maximum points of sin(x)/x due to the influence of the 1/x term. There are references to the limitations of manual calculations for finding critical points, indicating a recognition of the problem's difficulty.
ponjavic
x^x and sin(x)/x
The derivative of x^x is:
y=x^x
ln(y)=xlnx
(1/y)y'=lnx+x*1/x
y'=y(lnx+1)
y'=x^x(lnx+1)
Why is this not a possible way of solving it:
y=x^x
y=(e^lnx)^x
y=e^(xlnx)
y'=e^(xlnx)lnx
y'=x^x(lnx)
I see it's not the same answer but I wonder why
The reason is if the above was correct it would be easy to integrate x^x (which is not possible):
y=x^x
y=e^(xlnx)
integral(y)=e^(xlnx)/lnx
integral(y)=x^x/lnx
why is this not correct?
Ok I just realized that the inner derivative (do you also call it this?) of ln x is 1 thus
(e^(xlnx))'=e^(xlnx)(lnx + (inner derivative of lnx)) which is one thus x^x(lnx+1)
How does this affect the integral?
Secondly how would you go about drawing sin(x)/x by hand without a calculator
What I realize is the following:
Though not defined x=0 would seem to be at 1 mainly since for small sin(x)/x=x thus 1/x*sin(x)=1/x*x)=1
Next the function would reach the first zero (at the positive side) at pi/4 so how would the line look between 0 and pi/4? I have seen it but I don't know how to realize it myself.
Next I understand for x=pi/4->pi/2 since:
-__*\_/
it would look something like
Code:
 |_/
as opposed to
 \_/
slightly bulged to the left due to decreasing 1/x but where between pi/4 and pi/2 would the maximum be?
Following this the amplitude of the waves would just decrease which can be done by appreciation...
Any ideas?
ponjavic said:
y=x^x
y=(e^lnx)^x
y=e^(xlnx)
y'=e^(xlnx)lnx
The last step quoted is wrong. For the chain rule, you need the derivative of xlnx. Think it through again.
i don't think you did the derivative of the second one correct
from
y= e^(xlnx) the derivative of e^x is e^x dx
so
y' = e^(xlnx) (1)lnx + (x)(1/x) from the derivative of the exponent you go into the product rule
simplified this is
y' = e^(xlnx) (lnx +1)
y' = x^x (lnx + 1)
sometimes it's easy to forget simple thing like product and quotient rules when doing harder problems like this. you just have to think things though and not try to jump ahead of yourself.
"Secondly how would you go about drawing x*sin(x) by hand without a calculator"
Draw the two lines [tex]y=\pm{x}[/tex]
xsin(x) always lies in-between these two lines; you should be able to figure out how..
y=e^(xlnx)
y'=e^(xlnx)lnx
Let u = xlinx
du/dx= ?
my god, i meant sin(x)/x sorry =)
It's pretty much the same concept for [tex]\sin{x}/x[/tex], except instead you draw the lines [tex]y=\pm\frac{1}{x}[/tex].
Hope that helps! :)
Hope that helps! :)
I would say curves, rather than lines, but whatever..
In any case, you should also utilize the fact that sin(x)/x is an even function, so you only have to draw for positive x's.
Also, scale your horizontal axis so that [tex]x=n\pi[/tex] for integer n's are easy to place (at these points, your function is zero).
yeah that would probably give me the amplitude for the coming waves but for the first 0 to pi/2 it will go from 1->0 what will be the shape of this line and why? Also as I mentioned before the waves will be bent to one side. So +-1/x helps me get some sort of evaluation of the amplitude but not more than that...
Doh, I was thinking of [tex]x[/tex] as constant! *feels stupid* You're right, it's a curve.
-__*\_/
Code:
 |_/
as opposed to
 \_/
Any ideas?
There's a complicated way to prove that
[tex]\lim_{x\rightarrow0}\frac{sin x}{x}=1[/tex]
but early on, even if it's proven, it's just something you remember (you can also find this with L'Hopital's Rule).
You can also evaluate the opposite limit:
[tex]\lim_{x\rightarrow\infty}\frac{sin x}{x}=0[/tex]
(sin x) can have a max value of 1 and a min value of -1. (x) just keeps getting bigger as you approach infinity. 1 (or -1) over infinity is almost zero, so you know you're getting closer and closer to zero. The fact that the value of sin x can range from -1 to 1 means you have to cross zero.
You just have to figure out where the zero crossings are (every [tex]\pi[/tex] ). Then you ought to get a feel for how the max values between each zero vary.
Test [tex]\frac{\pi}{2}, \frac{3\pi}{2}, \frac{5\pi}{2}[/tex] etc.
(You might notice that the max values are just the reciprical of x with just the sign changing).
If you wanted to, you could also use your first derivative test and second derivative test to find your local maximums and minimums and your inflection points.
I would like to disagree with
You just have to figure out where the zero crossings are (every ). Then you ought to get a feel for how the max values between each zero vary.
pi/2 3pi/2 5pi/2 (couldn't reproduce the formula)
According to my calculator the minimum between pi/2 and pi/4 is: x=4.49...
while 3pi/2=4.71...
This is due to the descending 1/x multiplayer which displaces the minimum point/maximum point and gives the curve another shape
And the derivatives would give cos(x)-1/x^2=0 which is clearly not solvable with paper/pencil so that doesn't help me I think
Ignore first.
Edit: I misread your post.
[tex]dy(\frac{sin x}{x})=\frac{x cos x-sin x}{x^2}[/tex]
Finding 0= x cos x - sin x is harder, but it is the only way (I forgot - you can ignore the denominator when you're looking for the zero points, but they push you max/min points since the number you're dividing by keeps getting bigger)
I have to think about this one.
again mistake by me i though sin(x)+1/x
You could also use the Newton-Raphson method, but that's more fun on a spread sheet than manually (in this case, it takes about 4 or 5 iterations to converge).
You also know the max gets pushed low, but only by a small amount (in fact, close enough one might not even notice unless they looked close). And the max gets closer and closer to being right on one of the 90 degree points (diff goes from .22 rad to .13 rad to .09 rad to .07 rad).
yea... just make sure that u chain rule ALL of the steps, especially if u are dealing with variable to variable or function to function. also, the "inner derivative" is just called the last term of the chain rule.
Answer for X^X
y=x^x
ln(y)=xlnx
(1/y)y'=lnx+x*1/x
y'=y(lnx+1)
y'=x^x(lnx+1)
y=x^x
y=(e^lnx)^x
y=e^(xlnx)
y'=e^(xlnx)lnx XXX
y'=x^x(lnx)
y=x^x
y=e^(xlnx)
integral(y)=x^x/lnx
Answer y=e^(xlnx) => y'=e^(xlnx)(lnx+1)
again... I realized that, thanks for the help but please read the whole post =)
  • · Replies 18 ·
