What is the Distance of Closest Approach Between Two Point Charges?
  • Thread starter Thread starter purduegirl
    Approach
The discussion focuses on calculating the distance of closest approach between two point charges using conservation of energy principles. The initial kinetic energy of the moving charge is converted entirely into potential energy at the point of closest approach. The relevant equation involves Coulomb's Law, expressed as U = K*[q*q/r], where U is potential energy, K is Coulomb's constant, and r is the distance sought. Participants confirm that the total energy remains constant throughout the process, leading to the conclusion that the closest distance of approach is approximately 0.404 m. This problem illustrates the application of energy conservation in electrostatics.
purduegirl
Use the similarity between Coulomb's Law and the Law of Universal Gravitation to calculate the distance of closest approach between a point charge of +3.40 × 10-6 C, which starts at infinity with kinetic energy of 8.70 J, and a fixed point charge of +1.15 × 10-4 C. Assume that the moving charge is aimed straight at the fixed point charge.
Just use conservation of energy. What's KE+PE at infinity? At closest approach, KE=0, since the point charge has stopped. But the total energy hasn't changed, right?
I don't understand. Initially total energy and ending with total potential correct? How is this solved?
take the two point charges as system! now all the Columbian and gravitational forces are internal forces and hence mechanical energy is conserved.
just use KEinitial + PEinitial = KEfinal + PEfinal
find PEfinal and use it to find the distance at that time
Okay, i knew total energy is conserved. for anyone who needs it in the future, the closest distance of approach is when all kinetic energy is converted to potential energy. the problem can be solved using this equation: U = K*[q*q/r] where U = potential energy, K = coulomb's constant (8.9875E9), the q's are the respective charges of the particles, and r = distance of closest approach.
Notice that it is just r instead of r squared. this is enegry instead of charge force.
Is the answer to this problem 0.404 m? Thanks
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
