What is the drum's angular acceleration?
The angular acceleration of a drum rolling down a slope without slipping is defined by the formula α = a/R, where 'a' is the linear acceleration of the drum's axis and 'R' is the drum's radius. The relationship between linear and angular quantities is established through the equation v = ωR, linking linear speed to angular velocity. The discussion emphasizes the importance of selecting appropriate coordinate axes for analyzing the motion, with the x-axis aligned with the ramp and the z-axis perpendicular to it. The correct interpretation of vector quantities is crucial for solving the problem accurately.
  • Understanding of angular acceleration and linear acceleration concepts
  • Familiarity with polar coordinates and vector quantities
  • Knowledge of the right-hand rule for determining angular motion
  • Basic principles of rotational dynamics and kinematics
  • Study the relationship between linear and angular motion in rolling objects
  • Learn about the right-hand rule and its applications in rotational dynamics
  • Explore the derivation of angular acceleration formulas in various contexts
  • Investigate the effects of friction and slipping on rolling motion
Students and professionals in physics, mechanical engineering, and anyone interested in understanding the dynamics of rolling objects on inclined planes.
Reshma
A drum of radius R rolls down a slope without slipping. Its axis has acceleration 'a' parallel to the slope. What is the drum's angular acceleration? Please help me solve in polar coordinates.
since the drum rolls without slipping:
Angular Acceleration = α = a/R
to understand this, what's the relationship between the linear motion of the drum's axis (moving down the ramp) to the rolling outer surface circumference? remember, there's no slipping.
Linear speed v = \omega R
So if T is the time period, distance in one revolution = circumference
vT = 2\pi R
Please note that the motion here is downhill(clockwise) so there will be changes in the sign if we take into account the direction. So how do I make these changes?
vT = 2\pi R
remember that linear velocity (v), linear acceleration (a), angular velocity (ω), and angular acceleration (α) are all vector quantities. when solving a problem, one of the first jobs is to select convenient (orthogonal) coordinate axes into which these vector quantities can be projected into their coordinate components.
for your problem, it's typical to consider the ramp with highest level on the left, lowest level on the right, with motion from "left-to-right". then it's also typical to establish a coordinate system consisting of:
1) "x" axis parallel to ramp surface, (+) direction left-to-right
2) "z" axis normal (perpendicular) to ramp surface, (+) direction upward from ramp surface
3) "y" axis into page (normal to both above axes), (+) direction into page
for your problem, the linear motion is "left-to-right" along the "x" axis and thus its x-component is (+). the angular motion is clockwise, which according to the "right-hand rule", produces a (+) "y" component.
thus, for this problem, all quantities have (+) values for their components.
with the above in mind, and working with the aformentioned components, you basically have solved the problem.
beginning where you left off:
If T is the period of revolution, distance in 1 revolution = 1 circumference:
vT \ = \ 2\pi R
v \ = \ (2\pi /T) R
v \ = \ (\omega) R
\frac{dv}{dt} \ = \ a \ = \ \frac{d(\omega R)}{dt} \ = \ \frac{d\omega}{dt} \cdot R \ = \ \alpha R
EDIT: eh crap... made a mistake and your solution right I think
  • · Replies 17 ·
  • · Replies 71 ·
  • · Replies 33 ·
