What is the Effect of Reduced Air Resistance on an Object's Acceleration?
  • Thread starter Thread starter Dberry
    Force
The discussion revolves around the effect of reduced air resistance on an object's acceleration, particularly when the object is initially moving at a constant velocity. Participants are exploring the relationship between forces acting on the object, including air resistance and the propelling force.
  • Participants discuss the implications of constant velocity on net force and acceleration, questioning how changes in air resistance affect these dynamics. There is an exploration of the forces acting on the object and the necessity of understanding net force in the context of the problem.
The discussion is active, with participants providing insights into the forces at play and questioning the assumptions made about constant velocity and net force. Some guidance has been offered regarding the relationship between the forces, but no consensus has been reached on the correct interpretation of the problem.
There is an ongoing examination of the definitions and roles of the forces involved, particularly in the context of the problem's constraints, such as the assumption of constant velocity and the reduction of air resistance.
Dberry
If F is the force of air resistance on an object with mass m moving at a constant velocity, which of the following best describes the acceleration of the object when the force of air resistance is reduced by a factor of 4?
F=ma
The options listed are:
a) F/m
b) 1/2 F/m
c) 1/4 F/m
d) 3/4 F/m
My original thinking was that if there is constant velocity then there is no acceleration. But since that wasn't a choice I went with option c). However, the back of my book lists option d) as the answer, saying that the force propelling the projectile also has a force, so when the air resistance is reduced by a factor of 4 the net force must be F - 1/4 F = 3/4 F. I guess what I don't understand is why I have to subtract from the force projecting the projectile.
Thanks for your help!
To find the acceleration, you need the net force on the object. What two forces act on the object? When the object has constant velocity, what must the net force be? But when the air resistance force changes, so does the net force.
The forces acting on the object are air resistance and the force propelling it.
The net force must be zero because constant velocity means there is no acceleration, so according to F=ma F is zero.
The net force acting on the object right now are the two forces mentioned above and nothing else right? Or are the mass and velocity a part of the net force?
Right. And presumably the force propelling it does not change.
Exactly. So that tells you how big the propelling force is. (In terms of F, at least.)
Right. The vector sum of those two forces.
No.
To illustrate the problem I've created the following figures:
Before:
[URL]http://img63.imageshack.us/i/qbefore.png/[/URL]
In case image doesn't show (link): http://img63.imageshack.us/i/qbefore.png/
After:
[URL]http://img252.imageshack.us/i/qafter.png/[/URL]
In case image doesn't show (link): http://img252.imageshack.us/i/qafter.png/
As you see, the net force F[tex]_{net}[/tex] increases as air resistance decreases.
Something wrong with the latex subscript..
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 21 ·
