What is the effect of temperature on enzymes in poiklotherms
The discussion centers on the effects of temperature on enzymes in poikilotherms, exploring how these organisms adapt their metabolic processes to varying environmental temperatures. It includes considerations of enzyme activity, metabolic rates, and behavioral adaptations.
  • One participant questions how poikilotherms survive with fluctuating body temperatures and whether their metabolism ceases at high temperatures.
  • Another participant explains that poikilotherms have slower reaction times at lower temperatures and faster at higher temperatures, referencing the Q10 factor and behavioral adaptations like sunbathing to optimize internal temperatures.
  • It is noted that some poikilotherms, such as the Alaska Tree Frog, can survive extreme cold by freezing and thawing without fatal consequences.
  • A participant mentions that poikilotherms may possess multiple enzyme systems that function at different temperatures, leading to larger and more complex genomes compared to homeotherms.
  • Discussion includes the idea that poikilotherms generally have lower metabolic rates, which influences their hunting strategies and energy requirements compared to homeothermic animals.
Participants express various viewpoints on how poikilotherms manage temperature effects on enzyme activity and metabolism, indicating that multiple competing views remain without a clear consensus.
Some claims rely on species-specific temperature optima and metabolic adaptations, which may not apply universally across all poikilotherm species.
This discussion may be of interest to those studying biology, ecology, or animal physiology, particularly in understanding the adaptations of poikilothermic organisms to their environments.
Aafia
Since enzymes have particular temperature on which they are able to catalyze the reaction and increasing the temperature above optimum can damage enzymes then how does poiklotherms survive as they change their body temperature according to environment unlike homoiothems. Also wouldn't their metabolism stops on increased temperature?
Biology news on Phys.org
Poikilotherms have slower reaction times at lower temperatures, faster at higher temperatures. The Q10 factor applies here. This is why reptiles "sunbathe" in the morning, in order to raise internal temps closer to an optimum value, for example. So: no, the poikilotherms avoid extremes that would be fatal. Some adapt to cold, like the Alaska Tree Frog which can remain solidly frozen, thaw, and resume being a frog.
Desert reptiles avoid the extreme heat of day, staying underground in rodent burrows. Or buried 2-3 cm under the loose sandy soils. With a soil surface temperature >45°C the temperature 3 cm down in the soil column can be 15°C cooler.
So there are metabolic changes, as well as behaviors to cope with temperatures that are otherwise fatal.
FWIW - Temperature optimums are species specific.
For an important chemical reaction, poikilotherms may have four to ten enzyme systems that operate at different temperatures.[4] As a result, poikilotherms often have larger, more complex genomes than homeotherms in the same ecological niche. Frogs are a notable example of this effect, though their complex development is likely more important.[5]
Because their metabolism is variable and generally below that of homeothermic animals, sustained high-energy activities like powered flight in large animals or maintaining a large brain is generally beyond poikilotherm animals.[6] The metabolism of poikilotherms favors strategies such as sit-and-wait hunting over chasing prey for larger animals with high movement cost. As they do not use their metabolisms to heat or cool themselves, total energy requirement over time is low. For the same body weight, poikilotherms need only 5 to 10% of the energy of homeotherms.[7]
https://en.wikipedia.org/wiki/Poikilotherm
Now I understood. Thank you both of you
  • · Replies 23 ·
  • · Replies 0 ·
