What is the flux through one face of the cube? Is my answer correct
  • Thread starter Thread starter pokie_panda
    Cube Flux
The flux through one face of a cube with a point charge Q at its center is correctly calculated as Q/6ε₀, according to Gauss' law. The units for electric flux can be expressed as Nm²/C or equivalently as Vm. The discussion confirms that the dependence on the cube's side length L does not appear in the flux formula, as the electric field strength and surface area changes balance each other out. The charge unit is defined as coulombs (C).
  • Understanding of Gauss' law in electrostatics
  • Knowledge of electric flux and its units
  • Familiarity with the concept of point charges
  • Basic grasp of electric field calculations
  • Study the derivation of Gauss' law and its applications
  • Learn about electric field calculations for different geometries
  • Explore the relationship between electric flux and surface area
  • Investigate the implications of charge distribution on electric fields
Students studying electromagnetism, physics educators, and anyone looking to deepen their understanding of electric flux and Gauss' law applications.
pokie_panda
A point charge Q is placed at the center of a cube of side L .
Express your answer in terms of some or all of the variables Q ,L and appropriate constants.
I'm getting Q/6e0 , is this correct. Are the units Nm^2/C
Don't you think there should be an "L" somewhere in the formula? And what is "C"?
Yes, this is correct. A simple application of Gauss' law. Your units are also correct, although it may be simpler to express it as Vm (volt*metre).
Since the units of electric field are N/C, your units of Nm^2/C for flux seem fine to me.
C = coulombs
Gauss' law says the net flux through the surface is Q/e0, and since this should be divided equally among the six faces, your answer seems plausible.
I imagine that any L-dependence should cancel out, since surface area increases as the square of L, but electric field strength decreases as the square of L
Edit: beaten by one minute!
No, because they're asking for the electrical flux. The electric field calculation would involve L (and would not be trivial because the cube lacks spherical symmetry). C is coulomb.
Haha. :biggrin:
  • · Replies 17 ·
9K
