What is the formula for solving this Series/Sequence Problem?
  • Level: Undergrad
  • Thread starter Thread starter ae4jm
11 replies · 8K views
ae4jm
[SOLVED] Series/Sequence Problem?
I'm trying to figure out a formula for this sequence problem, rather than doing this over and over 1,000 times. Does anyone have a clue for the formula to find this? I've pasted the info and also the answer.
Thanks for your time!
Write out the formula for a1, a2, and a3 without summing and find the pattern so that you can write a formula for an that does not refer to an-1. It should remind you of a simple type of sum you already know a shortcut for.
{an} is defined, recursively, by a1= 4, [itex]a_{n+1}= a_n+ 4n[/itex]. Find a1000.
The first thing I would do is start calculating a few values (hoping I won't have to go up to 1000!).
a2= 4+ 4(1), a3[/sup]= 4+ 4(1)+ 4(2), a4[/sup]= 4+ 4(1)+ 4(2)+ 4(3).
Hmmm, looks to me like an= 4(1+ 2+ 3+ ...(n-1)) so a1000= 4(1+ 2+ 3+ ... + 999). Can you find 1+ 2+ 3+ ...+ 999? It's an arithmetic sequence with common difference 1. Or you could use "Euler's method".
Another method: rewrite the equation as:
an+1 - an = 4n;
so an+2 - an+1 = 4(n+1).​
Add them … what do you get … ? And then … ? :smile:
Gentlemen, I'm totally stuck. I sat here for the last 1.5 hrs and tried to figure this one out. I think that I'm making it too difficult. I've looked at the sequence all the way up through a6 and I'm just not seeing the formula.
I do know that to find the sum from 1 to 1000, would be (1000(1001))/2 or (n(n+1))/2. But I've tried finding the an like this also...dang I'm making this tuff aren't I?
Hi ae4jm! :smile:
Humour me … what's an+2 - an? … what's an+3 - an? :smile:
Hi ae4jm! :smile:
Yes … that's a3 - a1 and a4 - a1.
But you'll get more of an idea of what's going on if you answer the general question:
what's an+2 - an? … what's an+3 - an? (in terms of n):smile:
I believe that the first one is 6-4=2 and 7-4=3, right?
does this look correct for
Code:
[tex]a_{n}=4(\frac{n(n-1)}{2})+4[/tex]
:biggrin: Woohoo! :biggrin:
And now, of course, simplify it to 2n(n - 1) + 4.
Any questions? :smile:
Thanks! That was a dandy, for me anyways! I'm sure this practice will help me recognize these sequences a little better in the future. Thanks for sticking in there with me.
