What is the formula for work and how can it be defined?
  • Thread starter -Physician
    Work
7 replies · 2K views · last reply
-Physician
We will start with the work formula ##A=Fd##, can that formula be defined as:
##A=(ma)Δd=(m\frac{v}{t})vt=(m\frac{v}{t})v_0 t + \frac{1}{2} at^2## ??
##A=Fd##
Yes, it can be defined.
I think the answer will be yes, but I will be sure.ALSO: Can we define the work by velocity , mass or any other..?
If so, what's the formula
The equation is incorrect. ALWAYS check your units. When things are added, units must be homogeneous. 1/2at^2 has the units of length, not work.
Thanks, anyways:
, can you answer?
In certain cases you can equate work to kinetic energy. For instance if you pushed a block (initially stationary) on a frictionless horizontal surface with a constant force of F for a distance d, the following equation can be written:
F * d = 0.5 * m * v^2
where
F is force
d is distance
m is mass
v is velocity
Note that the units to the left and right of equals sign are the same. This always is the case.
where
F is force
d is distance
m is mass
v is velocity
thanks, but can I know why ##0.5## is put there and why is the velocity squared ##v^2##? What's the effect of that?
##v^2=v_0+2aχd## would give us the equation ##E_k=\frac{1}{2}mv^2=\frac{1}{2}aFt^2## E_k is Kinetic Energy, Now I understand the 0.5, But What I don't understand is why did you multiply the force ##F## with distance ##d##?
See derivation of kinetic energy formula : http://www.indiastudychannel.com/projects/1644-Derivation-Kinetic-energy.aspx
http://answers.yahoo.com/question/index?qid=20110530195816AAVPotW
Work is simply defined as mathematical product of force times displacement in direction of force or resolved in component of that force. What to say when you do work ? Push wall and it does not move. You do no work. That's the concept which implies meaning of the word "work" in physics.
By the way , your equation is also incorrect...
Correct will be to write :
v2=v02+2ad
v2=v02+2ad
thank you. got it now :)
