What is the Height of a Window Above the Ground?
  • Thread starter Thread starter Brock Skywalk
The discussion revolves around a physics problem involving an object dropped from a window, with a focus on calculating the height of the window using kinematic equations. The subject area is kinematics, specifically dealing with free fall and acceleration due to gravity.
  • Participants discuss the application of kinematic equations to determine the height of the window, with some expressing confusion about which equations to use. There are attempts to clarify the meaning of variables and the implications of direction in the context of acceleration.
The discussion includes various attempts to apply kinematic equations, with some participants providing guidance on understanding the equations and their components. There is an ongoing exploration of different interpretations of the problem, and participants are actively questioning their understanding of the concepts involved.
Some participants mention specific values for time and acceleration, while others express uncertainty about the correct application of the equations. There is a recognition of the need for clarity regarding the signs of the variables involved.
Brock Skywalk
1. AN OBJECT DROPPED FROM A WINDOW OF A TALL BUILDING HITS THE GROUND IN 12.0s. IF ITS ACCELERATION IS 9.80m/s^2, THE HEIGHT OF THE WINDOW ABOVE THE GROUND IS?
2.Not sure again
3. Not sure
your assistance is appreciated. -Skywalker
Hello Brock, welcome to PF! Please read and follow the rules, and you will get better attention. Since you are new... There are 4 standard kinematic equations for constant acceleration that you should memorize. You won't memorize them overnight unless you brother calls you Rainman for some reason. Just do as many of these kinds of problems as you can and you will get there someday. They are these (shown for x-direction motion, but same for y-direction with different subscript):
vx = vx0 + axt
x = x0 + (1/2)(vx0 + vx)t
x = x0 + vx0t + (1/2)axt2
vx2 = vx02 + 2ax(x - x0)
So if you know t, ay, vy0, y, and you are looking for y0, which equation shows promise?
Ok, i am still confused. what do i do first? thanks again for the reply sir. i appreciate it.
-Skywalker
you need to know what the 4 equations stand for first.
v = u + at
v2 = u2 + 2as
s =(1/2) (u+v)t
s = ut + (1/2) at2
to understand these equations you can imagine the following
if skywalker walks a distance "s" in time "t"
his speed at the start of the walk is "u"
and his speed at the end of the walk is "v"
and these 4 equations give the relationship between "s","t","u","v"
so assuming a question gives you "v","u","t" ,"a" but it didn't give you "s",
so you would use the first equation v = u + at, because this equation doesn't involve "s".
and likewise.
But i am trying to calculate the distance. what is given is (t) which = 12s and a = 12m/s^2. i am not sure which one to apply.
ok. i got 117.6 M. i used equation #1. what do y'all think?
You calculated v, not s.
You know this:
t = 12s (given)
a = 9.81m/s2 (given, though it is really -9.81m/s2 because it is in the downward direction).
u = 0 (given-- the object is dropped, not thrown)
s is what you are looking for--the distance.
So, which of quietrain's excellently simplified and well-explained equations has t, a, and u on the right hand side?
705.6 M. i used the last one.
There you go! Some other things to always do:
Draw a picture of what is going on.
Indicate your coordinate system and location of (x,y) = (0,0).
Use proper signs in front of v, a, even s.
Check if your answer makes any sense, if possible. Like units.
Thanks Lewando! i really appreciate this. this whole physics thing is a totally different monster. the math is simple is just know how to apply the formulas that i am having trouble with.
so could u explain what the variables stand for? a = acceleration t= time but what do the others really stand for?
ok. just did another.
an object is thrown vertically upward @ 35m/s. taking g = 10m/s^2, the velocity 5 seconds later is?
i got 85m/s.
i used v = v + a
whatta you think?
i got 85m/s.
i used v = v + a
I think "v = v + a" is not one of the equations. :smile: Precision is the key for good outcomes.
Looks like you used "v = u + at" without regard to the direction of a.
What direction is a acting in?
yes it was v = v + a*t. what did i do wrong sir?
"a" should be downward, so should i have multiplied by (-10m) thus my answer being 15m/s?
Yes!
(v = u + a*t, u being the initial velocity)
Great! so 15m/s downward?
The answer that you should have got was -15m/s [-15 = 35 + (-10)*5]. The negative sign indicates downwardness. I missed that on post 14. You can say 15m/s (a magnitude) downward (a direction) and be correct.
What will get you in trouble is if you say -15m/s downward... it's a double negative of sorts.
yes sir. i understand now. thank u so much sir. i hope your a sir, lol! i really appreciate it. -Skywalker
  • · Replies 25 ·
  • · Replies 38 ·
  • · Replies 21 ·
