What Is the Initial Speed of a Bullet Fired into a Block?
  • Thread starter Thread starter Rubi22
    Momentum Motion
The discussion focuses on calculating the initial speed of a bullet fired into a block resting on a frictionless table. The bullet embeds itself in the block, which then falls off the table, landing a distance d from the edge. The conservation of momentum equation (Pi=Pf) is essential for determining the bullet's initial velocity, while the equations of motion must be applied to account for the block's vertical drop and horizontal displacement. The solution involves relating the final velocity of the bullet-block system to the initial velocity of the bullet.
  • Understanding of conservation of momentum principles
  • Familiarity with kinematic equations of motion
  • Knowledge of projectile motion concepts
  • Basic grasp of mass and velocity relationships in collisions
  • Study the conservation of momentum in inelastic collisions
  • Learn how to apply kinematic equations to projectile motion
  • Explore the relationship between horizontal and vertical motion in physics
  • Investigate examples of bullet-block collision problems in physics textbooks
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of momentum and motion principles.
Rubi22
First post here on the forum, so excuse me for any mistakes.
A bullet of mass m is fired into a block of mass M initially at rest at the edge of a frictionless table of height h. The vullet remains in the block, and after impact the block lands a distance d from the bottom of the table. Determine the initial speed of the bullet.
No variables are given, the answer should be in the form of an equation.
I'm having a really hard time starting this problem, but am pretty confident that with a hint I could get it taken care of. I'm thinking that the conservation of momentum equation (Pi=Pf) will help determine the velocity of the bullet, but I'm not sure how to compensate for the block falling off of the desk. Maybe the laws of motion equation? (X=Xi+VixT+1/2AT^2)?
Any help would be appreciated. I have the answer from the book, but am not sure how to figure it out. Let me know if knowing the answer would help. Thanks
You're absolutely right. Use the x equation to find the initial velocity of M and m (when they are together). Then relate that velocity to the initial velocity of the bullet before it hits the block. Is there a specific place where you have trouble? Don't forget that you have to consider the motion in the horizontal and vertical directions as the block and bullet are falling off the table.
  • · Replies 31 ·
