What is the magnitude of the magnetic field at the center of the arc?
The discussion focuses on calculating the magnetic field at the center of an arc due to a current-carrying wire configuration. A current of 3 A flows through a wire, with specific dimensions provided: L1 = 3 m, R = 6 m, and L2 = 6 m. The magnetic field contribution from the arc is calculated using the formula B = μ₀I/8R, while the magnetic field from the straight portions requires the Biot-Savart law for semi-infinite wires, as the standard formula for infinite wires is not applicable. Participants emphasize the need to correctly apply the Biot-Savart law to derive the appropriate equations for semi-infinite wires.
  • Understanding of Biot-Savart law
  • Familiarity with magnetic field calculations for current-carrying wires
  • Knowledge of magnetic field equations for infinite and semi-infinite wires
  • Basic principles of electromagnetism
  • Research the derivation of the Biot-Savart law for semi-infinite wires
  • Learn how to apply the Biot-Savart law to different wire configurations
  • Study the differences between magnetic field equations for infinite and semi-infinite wires
  • Explore practical applications of magnetic fields in electromagnetism
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetic field calculations or applications.
anna_628
A current I = 3 A flows through a wire perpendicular to the paper and towards the reader at A and back in the opposite direction at C. Consider the wires below the plane at A and C to be semi-infinite. In the figure, L1 = 3 m, R = 6 m, and L2 = 6 m and there is a B = 2.37 T magnetic field into the paper (not including the field due to the current in the wire).
Caution: It may be necessary to take into account the contribution from the long straight wire which runs up to and down from the underneath side of the page.
Image: http://img28.imageshack.us/img28/5329/newpictureiv.png
What is the magnitude of the magnetic field at the center of the arc O due to the current in the wire (T)?
This is what I've done so far:
For the arc portion of the circle, I used B = Mu(0)xI/8R
For each of the straight portion, I used the equation for a long straight wire, which is: B = Mu(0) x I/(2 x pi x a).
Since each portion of the wire is going in a different direction (i, j, k components), I took each field, squared it and added them all then took the square root. But this is not the right answer...Not sure where I'm going wrong?
This looks good.
What straight segments are you talking about? Note that none of them is infinitely long, which is what that formula is for. Discuss each straight segment separately.
I guess I thought that this equation was for semi-finite straight wires as well...I don't know what the equation for it is if it is not this...
That equation is for a straight wire that is infinite in both directions. To find the formula for a semi-infinite wire, start with the Biot-Savart law. Hint: Look up how the formula is derived for an infinite wire and you'll see how to modify the derivation for a semi-infinite one.
  • · Replies 20 ·
