What is the maximum current in a superconductor loop?
The maximum current in a superconductor loop is determined by the critical current density (Jc), which varies based on temperature, external magnetic fields, and the specific properties of the superconductor material. Superconductors can be classified into different types, with type-2 superconductors being most relevant for practical applications. The presence of pinning centers, which are non-superconducting regions, plays a crucial role in maintaining superconductivity by stabilizing the current flow. These pinning centers are influenced by various factors, including material composition, sample shape, and manufacturing techniques. Ultimately, the maximum current is a complex interplay of these variables.
fxdung
If we put an emf equal constant onto a superconductor loop(we consider the resister of emf equal zero), then what is the maximum of current in the loop?
Your superconductor will stop being a superconductor at a current that depends on the temperature and external magnetic field strength, and sometimes the current direction (and the material obviously).
To just elaborate on mfb's answer a bit, we typically define the maximum limiting current (density) in a superconductor by what is called the 'critical current': Jc.
Superconductors come in a variety of flavours, and the 'critical current' (density) is intrinsic to each superconductor material, fabrication process, shape, quality, and many more factors! Ultimately however, in type-2 superconductors which heed all real practical applications, the current that you can pass through the superconductor depends on the pinning centres of the superconductor. Pinning centres are regions of non-superconducting states; which sounds counterintuitive at first, but actually introducing non-superconducting regions helps `pin' and retain superconductivity. These pinning centres are thermally and magnetically dependent; depend on material, sample shape, crystalline quality, growth sectors, manufacture technique, size and relative number of impurities/defects - so to reiterate, are many, many factors!
16K
