Dc2LightTech
- 23
- 1
- TL;DR
- measuring astronomical distanced
using the Earths orbit, what is the maximum distance that can be measured using parallax error?
What accuracy/precision?Dc2LightTech said:TL;DR Summary: measuring astronomical distanced
How high is up?Dc2LightTech said:using the Earths orbit, what is the maximum distance that can be measured using parallax error?
Now you have a good question. What research have you done? What have you found so far?Dc2LightTech said:using the orbit around the sun, with current technology, how far can the best optical telescopes detect and parallax shift of a star using a distant galaxy as a reference for infinity.
It isn't as simple as resolution, by the way. If you have a diffraction-limited telescope, the Rayleigh criterion will give you the ballpark for the angular separation needed to see two distinct points rather than one, and that's roughly what you need here - you need to be able to compare two images and say "yup, that point is in a different place". The figure comes out in radians. Convert to arcseconds, and one upon that is the number of parsecs you can use the method to.Dc2LightTech said:using the orbit around the sun, with current technology, how far can the best optical telescopes detect and parallax shift of a star using a distant galaxy as a reference for infinity.
I suspect they usually aren't.Ibix said:Note that ground based telescopes may not be diffraction limited due to atmospheric conditions.
if knew the pixel/angular resolution of the best sensor. and the typical Pixel/cross section for a faint star then calculation is not a hard thing to do. should be easy in LabView. I did a orbital flight dynamics program in Labview for fun. Moon landing from unlocking in orbit to touchdown. this should be easy. might be easy to simulate it.phinds said:Now you have a good question. What research have you done? What have you found so far?
Of course he did. He told us to find the answer for him!phinds said:. Have you actually researched your question?
You could certainly build a CCD with 50 nm pitch, and maybe even 5 nm, although I have no idea how you would power it up without it bursting into flames - each square cm would have 4 trillion channels.Dc2LightTech said:if knew the pixel/angular resolution of the best sensor
