What Is the Maximum Electrical Force Between Two Protons in a Cyclotron?
The discussion revolves around calculating the maximum electrical force between two protons in a cyclotron accelerator, where the protons are aimed directly toward each other at a specified speed. The problem involves concepts from electrostatics and energy conservation, particularly relating to kinetic and potential energy.
  • Mixed
  • Participants explore the relationship between kinetic energy and electric potential energy to find the distance of closest approach. There are questions regarding the initial conditions and the definitions of variables such as V_i. Some participants suggest using Coulomb's law to calculate the force after determining the distance.
Participants are actively discussing the calculations needed to find the distance of closest approach and the subsequent force. There is a recognition of the need to account for the total kinetic energy of both protons. Some guidance has been provided regarding the algebraic manipulation of equations, but no consensus has been reached on the final calculations.
There is an ongoing discussion about whether the speed of the protons needs to be converted from km/s to m/s for the calculations. Additionally, participants are checking for accuracy in their calculations and addressing potential typos in their equations.
stylez03
Two protons are aimed directly toward each other by a cyclotron accelerator with speeds of 1350 km/s, measured relative to the earth.
Find the maximum electrical force that these protons will exert on each other.
Mass of Proton [tex]1.67 * 10 ^{-27}[/tex]
[tex]KE_{i} = PE_{f}[/tex]
[tex]\frac {1} {2} * m_{p}*v_{1}^{2} = \frac {1} {4*pi*8.85*10^{-12}}*\frac {Q_{2}} {R}[/tex]
I'm not sure where to go from here.
Find the distance of closest approach by setting the initial KE (total KE) equal to electric potential energy. Then use Coulomb's law to find the force.
What is V_i ?
stylez03 said:
What is V_i ?
What do you mean by V_i? The initial speed? That's given. The initial potential? Assume they start out infinitely far away from each other (for all practical purposes).
To find the closet approach, I'm solving for R as you said so it should be in the form of:
[tex]\frac { \frac {1} {2}* m_{p} * v_{i}^{2}} {K*Q^{2}} = R[/tex]
Looks to me like you are only counting the KE of one proton--use the total KE of both.
When we count both, would it just be KE_1 + KE_2?
[tex]2*(\frac { \frac {1} {2}* m_{p} * v_{i}^{2}} {K*Q^{2}}) = R[/tex]
That's right--just add up the KE. But fix that equation--I just realized that you have some factors inverted. The magnitude of the PE is kq^2/R.
Ah let's show each step:
[tex]KE_{i}1 + KE_{i}2 = PE_{f}[/tex]
[tex]2*(\frac {1} {2} * m_{p}*v_{1}^{2}) = \frac {1} {K}*\frac {Q_{2}} {R}[/tex]
[tex]2(m_{p}*v_{i}) = \frac {KQ^{2}} {R}[/tex]
We divide out KQ^2 to isolate R
[tex]\frac {2(m_{p}*v_{i})} {KQ^{2}} = {R}[/tex]
Good.
Typos in the right hand term.
Almost--that should be v_i^2. And the 2 cancels.
Do this step over. Note that R starts out in the denominator.
[tex]m_{p}*v_{i} = \frac {KQ^{2}} {R}[/tex]
Divide by [tex]m_{p}*v_{i}[/tex]
[tex]\frac {KQ^{2}} {(m_{p}*v_{i})*R}[/tex]
Multiply by R
[tex]R = \frac {KQ^{2}} {(m_{p}*v_{i})}[/tex]
Sorry my algebra is a little rusty
Good.
You mean:
[tex]1 = \frac {KQ^{2}} {(m_{p}*v_{i})*R}[/tex]
Multiply by R
Good.
No problem. Remember the cross-multiply trick. When you see this:
[tex]\frac{A}{B} = \frac{C}{D}[/tex]
You can convert to this:
[tex]A*D = B*C[/tex]
After I find the closet approach, you said to use Coulomb's Law to find the force. Is the R in here equilv to d in Coulomb's Law where:
[tex]F = \frac {K*Q_{1}*Q_{2}} {d^{2}}[/tex]
and F is what I'm after in t his problem?
Yes and yes.
[tex]R = \frac {KQ^{2}} {(m_{p}*v_{i}^{2})}[/tex]
[tex]R = \frac {(8.99*10^9)*(1.60*10^{-19})^{2}} {(1.67*10^{-27})*(1350)^{2}}[/tex]
[tex]R = \frac {2.30*10^{-28}} {4.50*10^{-24}}[/tex]
[tex]R = 0.000051[/tex]
[tex]F = \frac {(8.99*10^9)*(1.60*10^{-19})^{2}} {(0.000051)^{2}}[/tex]
[tex]F = 8.84 * 10^{-20}[/tex]
Can someone verify my calculations, the online program says it's incorrect. I think I did everything right, I'm wondering if km/s needs to be converted into m/s?
stylez03 said:
... I'm wondering if km/s needs to be converted into m/s?
Absolutely.
  • · Replies 23 ·
