What is the maximum magnetic field strength?
The maximum magnetic field strength of a vertically polarized radio wave with a frequency of 1.0 x 106 Hz and a maximum electric field strength of 1000 V/m can be calculated using the relationship E = cB, where c is the speed of light (3.00 x 108 m/s). This results in a maximum magnetic field strength of approximately 3.33 x 10-6 T. For a point where the electric field strength is 500 V/m, the distance to the nearest point of maximum magnetic field strength is determined to be 50 m, which is 1/6 of the wavelength (300 m) of the wave.
  • Understanding of electromagnetic waves
  • Familiarity with the relationship between electric and magnetic fields (E = cB)
  • Knowledge of wave frequency and wavelength calculations
  • Basic trigonometry for calculating distances on a wave
  • Study the derivation of the relationship between electric and magnetic fields in electromagnetic waves
  • Learn about the properties of sinusoidal waves and their amplitude
  • Explore the concept of wavelength and frequency in electromagnetic radiation
  • Investigate the applications of electromagnetic waves in communication technologies
Students and educators in physics, particularly those focusing on electromagnetism, as well as professionals in telecommunications and related fields seeking to deepen their understanding of electromagnetic wave properties.
dtesselstrom
The figure shows a vertically polarized radio wave of frequency 1.0 times 10^6 traveling into the page. The maximum electric field strength is 1000V/m.
What is the magnetic field strength at a point where E=500V/m down
What is the smallest distance between a point on the wave having the magnetic field of part b and a point where the magnetic field is at maximum strength?
Not sure
only equation it gives in book ins I=Io*cos^2(theta)
I really have no idea how to even start this problem our physics book doesn't give any relationships that I can find to calculate this problem. If someone could provide with me the equations that can help me or a source that explains this kind of situation it would be helpful.
The equation you list is useful if you would like to calculate the output power of unpolarized light going through a polaroid filter.
Therefore I'm not sure what kind of EM you're studying at the moment. There is an equation that relates the electric and magnetic fields of an EM wave. It is based on the known fact that the energy is distributed evenly among the two.
E = \frac{B}{\sqrt{\epsilon_0 \mu_0}}
Obviously I'm seeing this a bit late to help the person who originally posted, but in case anybody else has issues...
The post before this is correct - the easiest way to calculate an EM wave's magnetic field from its electric field, or vice versa, is to remember that energy is shared equally between the fields.
E=\frac{1}{\sqrt{\epsilon_{0}\mu_{0}}}B
\frac{1}{\sqrt{\epsilon_{0}\mu_{0}}} is the speed of light, c, which is equal to 3.00\times10^{8} m/s.
E=cB
Answering the first two questions should be simple here. Since it doesn't appear that you are being asked for a direction/phase sign, you shouldn't need to use the right-hand rule.
For the last question, consider the amplitude of E. You are told that the maximum E-field is equal to 1000 V/m. This corresponds to a maximum of a sinusoidal wave with an amplitude of 1000 units. You are asked to find the shortest distance on the wave between this point and a point where the E-field is 500 V/m, or half the amplitude. Since E-fields and B-fields are not measured in meters, you are really being asked to find this distance on the axis of propagation. If we take the simple unit circle of circumference 2\pi, and find the distance on the circle between the point where the y-value is 1 (the maximum) and a point where the y-value is 1/2 (half of the maximum), we calculate the length of that section of the circle is
\frac{\pi}{2}-\frac{\pi}{6}=\frac{\pi}{3}
which is 1/6 of the total circumference. Since one turn of the circle represents one complete wavelength, and we know that the frequency of the wave is 1.0\times10^{6}s^{-1}, we can calculate
\lambda=\frac{c}{f}=\frac{3.0\times10^{8}ms^{-1}}{1.0\times10^{6}s^{-1}}=300m
1/6 of the total wavelength is 50m.
Sorry for the wordiness - a picture would have helped for the last question.
Matt Kramer Madison, WI mfkramer@wisc.edu
