What is the objects velocity when it hits the earth
  • Thread starter Thread starter martine80
    Earth Velocity
12 replies · 3K views
martine80
Hi, I am a student from norway, and I am strugeling with this problem, hope someone can help me og guide me in the direction:
A object is brought out in space in a distance of 3(6,37*10^6) from the senter of the earth. not any velocity when the object is released in space.
1) What is the objects velocity when it hits the Earth ( this I've solved)
2)
i)how long does the object use halfway towards the earth?
ii)how log does it take until the object hits the earth?
HELP PLEASE!
Write down the equation for conservation of energy, with speed written as a derivative.
how do i do that?
so far I've come up with this:
2*R(radius of the earth)=3R-integrate from 0 to t(1/2(integrate from 3R to 2R(-G*M(Earth)/r^2)) *t^2
martine80 said:
how do i do that?
I'm not sure what you're doing here.
To make sure things are OK, just write down the conservation of energy equation, and leave the integrals until later.
I use : 1/2 mv^2
and Gravital Potential energy, and unerversial of gravity = Gm(1)m(2)/r^2
martine80 said:
I use : 1/2 mv^2
Let R be the radius of the Earth, and suppose that the object is a distance r from the centre of the Earth. If the object starts at rest from 3R, what is the *equation* for conservation of energy.
:cry: I don't know, I've sat down with a teacher and he didnt know eather , just the equation i told you about
Let K be kinetic energy and V be gravitational potential energy.
K_initial + V_intitial = K_final + V_final
Can you substitute expressions for each of the terms in this equation?
I know, but i toght i was suppose to use potentional energi in this ? I am not sure... I am about to give up now. As far as i know I am supose to end up with an integral I have to use Maple to solve ...
:confused: Again, I'm confused. My equation involves potential energy.
If you'll substitute expressions (that I think you know) into the equation that I wrote previously, I'll help you get the integral, but, since this is homework (and thus should be in the homework section), I'm, at this point, not going to write down the answer.
hehe, no its not homework, I don't have to do this ... Its voluntary
I come jp with this :
1/2mv(0)^2+ G M(earth) m(object) (1/r1-1/r2)=1/2mv^2+ G M(earth) m(object) (1/r1-1/r2)
Im sure its wrong :(
Almost.
If the object starts from rest, then, initially, v = 0, so K_initial = 0. This gets rid of one of the terms in the equation.
Also, the gravitation potential energy (of the system) when the object is a distance r from Earth's centre is
V = - G M m/r^2.
Use r_initial and r_final to get V_initial and V_final.
Because of work and family commitments, I might not be able to get back to this thread until tomorrow.
George Jones said:
Almost.
V = - G M m/r^2.
V initial = 0 and Vfinal is 2GM(E)/3radius of the Earth ...
Thank u for yore time , Ill let you know by tomorrow if I've solved the problem!
