B What is the origin of the Gibbons-Hawking temperature?
  • B
  • Thread starter Thread starter Tim Miller
    Origin Temperature
The Gibbons-Hawking temperature, noted as approximately 10^-29 Kelvin, is associated with the cosmological horizon and reflects the influence of the cosmological constant in our universe. This temperature is not absolute zero, as it is a positive value, indicating that nothing within the cosmological horizon can be colder than this limit. The discussion highlights the distinction between this theoretical temperature and classical absolute zero, emphasizing that the latter is a heuristic concept rather than a strict physical definition. There is uncertainty regarding the microphysical model of this temperature, and while it is thought to be a fundamental property of spacetime, the exact nature of its implications remains unclear. Overall, the Gibbons-Hawking temperature represents a unique aspect of cosmological physics that differs from traditional temperature concepts.
Tim Miller
I recently submitted the following question to Dr. Michio Kaku on his Facebook page regarding an unfamiliar concept in his book "Parallel Universes":
Dr. Kaku,
In your book "Parallel Universes", pg. 301, you mention something called the Gibbons-Hawking temperature, a theoretical low temperature limit of 10 negative log 29 degrees (is that Celsius of Kelvin?). You cited a work by Lawrence Krauss & Glenn Starkman. Can you give me the full citation for this work? Is this it: http://iopscience.iop.org/articl...? How does this relate to the absolute zero of classical physics (−273.15 °C; −459.67 °F), a theoretical point at which nearly all atomic/molecular motion ceases?
Space news on Phys.org
I believe this temperature (in Kelvin) is the temperature associated with the cosmological horizon due to the nonzero cosmological constant in our universe. Nothing in our universe (more precisely, in the causal patch within our cosmological horizon) can ever be at a lower temperature than this.
Thanks for your reply! I'm still wondering how this number was arrived at and why scientists don't now call this number absolute zero instead of −273.15 °C / O°K.
Any horizon has a corresponding temperature associated with it. For the cosmological horizon in de Sitter spacetime, the temperature is proportional to the cosmological constant. I can't dig up an exact formula on line at the moment, but AFAIK the temperature ##10^{-29}## Kelvin is what you get when you plug the best current value for the cosmological constant in our universe into the appropriate formula.
Because it isn't. The temperature associated with a horizon is not zero; it's positive. (Note that any time you see a temperature in physics or cosmology, it will be an absolute temperature unless it's explicitly stated otherwise, since the absolute temperature scale is the one that makes all the formulas involving temperature look simple.) The idea that absolute zero is "the lowest possible temperature" is only a heuristic; the actual physical definition is different.
Is that last sentence strictly true? My thought was that this temperature was similar to the CMB temperature in its impact on temperature of other bodies, and there are objects out there with temperatures lower than the CMB (e.g. the Boomerang Nebula). Nothing can stay at a lower temperature than the CMB for too long, because eventually it'll reach equilibrium. But they can definitely go below that temperature temporarily.
I'm actually not sure whether that is true or not. If it is true, then yes, I think it would be possible to temporarily cool something below this temperature. But there might be other effects involved with the temperature associated with a horizon that are not present with the CMB.
The way I might imagine it could be true would be if this temperature were a fundamental property of the space-time, rather than just photons created at the horizon that fill the universe.
I'm actually not sure that either of these is a good description of the temperature associated with a horizon. We don't have a good microphysical model of how such a temperature arises, so we can't be sure.
My suspicion is that ultimately, it doesn't actually matter. I'm pretty sure the universe where this temperature is relevant is an empty universe. That's a de Sitter universe, which is a stationary state. If such a universe is in a stationary state, then the finite temperature would just be an apparent temperature that has nothing to do with the underlying space-time. E.g. there would be no temperature fluctuations. This is the universe described here: https://arxiv.org/abs/1405.0298
Just to be clear, the paper you linked to is a hypothesis about de Sitter spacetime; it is not a known fact about de Sitter spacetime. I don't know that the conclusions of the paper are generally accepted among physicists.
If the temperature is positive, the why is it expressed with a negative exponent?
##10^{-29}## is greater than zero, so it's a positive number.
Because it's less than one. E.g. ##10^{-1}=0.1##, ##10^{-4}=0.0001##.
Thanks for the refresher. My memory is not what it used to be.
